So whats the strongest aluminum block?
Originally Posted by Honeycutt
Meh, like you said, that's an opinion. The caps will start moving around the 4 digit mark, 1000hp is not the magic number where you start lifting heads, there are more than a handful of people making over 1000hp on a 4 bolt block. Pinning the mains is a minimal cost compared to an LSX block.
ok...
ZR1 was an LS9 block
Alot of differences in an LS9 block and an LS3 block...
LS9 has oil squirters, LS3 does not
LS9 has 12mm head fasteners LS3 has 11
LS9 has steel main caps, LS3 does not.
Theres more but thats 3 off the top of my head.
LS9 is the strongest stock aluminum block.... followed by a later 5.3 block/LS3/LS2.
UNDER PRESSURE MOD
When I was looking at my options last year, I wanted to stay aluminum for the weight, and I wanted the extra cubes for low end torque. I tried to read up as much as I could on the differences in the ls9/lsa/ls3 blocks, and didn't see much differences in the castings or strength, it was the extra add ons after the fact that were different.
For me, I don't see myself ever exceeding 1000rwhp, so the ls3 is the route I chose.
It's came out in 2006-2009 trucks, Tahoes, Yukons, and a couple other vehicles . All aluminum 5.3 blocks are not sleeveble . I've brought this up more than once as I plan on building a 430 plus cube motor.
Well Ron if you looked on the right front facing of the block you'll see a casting number. I was informed this info by Racing Engine Development . The two casting numbers that I know that will work for resleeving are 12571048 and 12571043. I have the one that ends with 48.....
I have an 06 L33.
I'd like to eventually find another block for a spare. Just in case.....
No desire to sleeve though.
http://www.ls-guy.com/geniv
This guide is pretty handy
The oil squirters are an add on, as are the bigger head fasterners, steel main caps can be considered an add on as well that you can go to billet mains if you wanted to for an ls3. I thought he was just asking about the actual block casting.
#33
If you go have the block sleeved.... go with a 5.3 aluminum block. Best bang for the buck as they can be had for around 300 bucks. Ray Litz and the Ohio boys all run those blocks to power they cars to 7s in the quarter mile.
#35
2008-2009 Canyon/Colorado/Hummer H3 were available with the LH8 which doesn't have VVT or DOD. 2010-2012 was the LH9 and had VVT, no DOD. Only full size trucks with the 5.3 had DOD and/or VVT depending on year. Very few 5.3s were put into the 355 series trucks, and I'm glad I got one.
#36
i have one of those late 5.3 blocks sitting around. whats the most inches i can get out of it?
i did some reading lately and it seemed to me the lsa was a good bet. its a different(stronger) alloy than the ls2/3 blocks, has cast in liners instead of pressed in, and comes with squirters
http://www.ctsvowners.com/forum/4-en...tml#post310191
#37
The LS9 block is superior mainly due to the clamping force of the head bolts. 120 ft/lbs with ARP 12mm bolts can contain much more cylinder pressure than a 5.3. It is also cast from a better grade aluminum, billet main caps, plus piston squirters which evens out the temps in them vs more heat in the center without. Lastly you can run a larger valve being 4.065" bore.
I made over 1200rwhp with a stock LS1 crank, Compstar rods in one. But then again.... it doesn't cost $500
