Crankcase venting
Crankcase venting
I know it's been beat to death but I got a question. What about using 2, 10 AN fittings like they put on oil pan for the turbo drain on each valve cover? I was thinking of bolting 1 on each valve cover, 10 hose on 1 to a catch can with breather, and the other to a 1 way valve in the down pipe. Why wouldn't that work?
i personally don't find there is anything to gain putting around on the street with a vac pump spinning unless your pockets are too heavy.
if you do have one you should really have a regulator so you can crank it up at the track and crank it out for normal driving.
Question for you guys that run the PCV to the downpipe... Is there any rule that you should or should not run a wideband O2 downstream of where the pcv line attaches? Is there any reason that the PCV attachment would effect O2 readings? Just something I was thinking about.
"I'll take "read error" for 500, Alex."
