Cam Gurus step in
Cam Gurus step in
If this needs to be moved- move it!
Car will have a 5.3/T88 or twin China 70s. Ls1 intake. M6. Top end power is paramount
I trash picked this cam (no joke) from a local shop. Has a scored jounral I will fix. Made 860whp on a twin 35r GTO with a 6.0, and carried power to 7200 rpm. But, will this work well in a 5.3? Seems like a lot of lift.
Duration at .050 - 240/244
Lift with 1.7 - .620/.603
Opinions welcome!
Opinions welcome!
Top end power is paramount...with cheap chinese turbos ? Almost seems counter productive ?
And regardless of LSA etc, that sounds like a hell of a big cam for a 5.3, maybe once over 5-6k as long as EGBP is nice and low, maybe it will work ok.
I dont think I'd want to risk it though but others will have more experience
Lobe separation 114
Intake center line 110
Twin 78/75's certainly wont do anything on the low end The car is a 1/2 mile/standing mile car-so low end be dammed!
Its a big cam, but the follow up would be what is a "medium" cam that will truly carry power to 7500+rpm if I need it?
It's all very well saying low end be damned, but going too big can kill power at the low end, make it very crap to spool, and do almost nothing at the top end to make up for the loss at the lower areas.
Whereas a milder cam just works everywhere.
If it's a mile car, the last thing you want is it to be a dog every time you change gear.
IMO the biggest hurt to wanting 7500rpm+ is probably the LS1 intake....but a bigger cam may get you there
IMO the lift isnt the concern for a 5.3, the duration and potential overlap may be of more concern.
If you have it, try it.
I agree with you 100% avergae power is very important, and for easy and enjoyment of street driving, paramount.
I agree the Ls1 intake may hurt top end flow-but after making near 900whp with a stcok intake and cam, I am not so worried about it. It will be interesting to see what the graph looks like after 6500rpm, as I think the car it came off of had a Fast intake so I have a base of comparrison.
I guess a good way to look at my question is if this cam could be changed to be better for a turbo car looking for power from 5500-7500, what would be the change and why? Im just not swift on LS cam theory
I mean hell I am trying to use a cam I trash picked for goodness sake!
Now what do you mean what "lobes"? You speaking of ramp rate? Its a CamMotion Cam, I am not sure they offer different ram rates per say. I have a call into them to get more info.
After doing some reading it looks like there is a lot of debate on overlap/lift for turbo applications. But in the end-there is a LOT of opinion and very little fact. Even the guys going fast say what worked for one combo did not work for another. Most people say you want less overlap, but some of the fastest guys that actually shared their experience showed the best MPH/ET with the highest overlap cams they tried.
Oye
