Boosted ls6 cam recommendations?
I have a C5 Z06 Corvette that I am throwing around what Cam to use. It is a stock motor right now, it has a Paxton Novi 1500 on it with around 10lbs, boost a pump, method injection, 80lbs injectors, LG super pro long tubes, X pipe, bullets. RPM 4l60e, 3600 coan, 342 gears, weld RTS, around 3200lbs. I was looking at the BTR stage 3 boost cam from Lil John motorsports Cam specs are 230/235 .609"/.610" 114+4 and comes a 3 bolt timing gear pattern. What would you all recommend? I'm up for options. I also have 243 heads currently, thought about using 317 cast number but also up for curiosity? Whichever heads I choose will be worked over professionally, thanks for your input.
