max boost for a 402/403 without overspinning f1a
so im getting ready to bite the bullet and purchase my headunit. im looking for a max boost at around 18lbs on my 403 with an f1a this is on an fbody with the procharger fmic, big red bov and aster bracket. going to use the procharger 7.65 crank pulley.
my setup is looking like this
ls2 aluminum block. depending on staying 4.000 or go to 4.005
weisco/diamond pistons, compstar rods, dragonslayer crank
frankenstein porter castings trickflow cnc heads. should be in the 227cc range
shooting for 10. to 1 compression.
custom speced cam by martin or geoff at eps
brian tooley .650 dual spring kit with titanium retainers
ported fast 102 by chris frank and 102 nw tb
kooks 2 inch x 3 headers into there newly designed 3 inch y into a cut out and magnaflow catback
Originally Posted by Detoxx03
How much power are you shooting for?
Don't worry about the psi number too much. It's only a measurement of restriction. If the setup is efficient it can make 900 on 15-16psi or 18-22psi. Just depends on intake, heads, cam, exhaust flow, etc.
Just throw a 4.2 or 4.0 on it and see if you hit your goal. If not throw a bigger or smaller pulley on it depending on which way you need to go.
LS1Tech Sponsor
To determine the impeller speed, the following formula is used:
Maximum impeller speed = crankshaft pulley diameter (N1) divided by supercharger pulley diameter (N2),multiplied by the step-up ratio (4.10 for the P-series/D series - 5.40 for the F series), multiplied by engine rpm at redline.
7.65 divided by 3.90 x 5.40 x 6800 rpm = 72027 rpm
A 3.90 pulley is what I would go with. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
