*Vs 77/83* turbo g body
#81
Ive done a ton of ls Swaps but I have no experience tuning efi, only the carb stuff. The microsquirt does seems pretty straight forward and easy to navigate through but I can't seem to get this thing to idle at all. Fires up and dies immediately if I'm not on the throttle. I'm assuming it's the tune and my lack of tuning knowledge/experience lol.. It has Denmah's gasoline Fairmont fuel and spark ve tables atm. I blocked off the IAC passage in the throttle body, played with the idle set screws a bit. I don't have a wideband atm so that's not helping smh.. Any suggestions as to what I might be able to mess with to get it to idle somewhat?
#83
#85
#87
Thanks!! It's getting there slowly. Haven't really been able to mess with it much, too much other stuff going on and now I'll be moving soon so that may slow things down a bit. Its always something lol. Do you have a build thread going?
#88
Soooo I got the car to idle without having to stay on the gas. Well rookie mistake, I somehow had 4 squirts per engine cycle enabled. Looked at a microsquirt video by Aknovaman and noticed he had only 2 squirts, so I gave it a shot and I'll be damned!! Oppps lol. Lesson learned. Will be getting a wideband so I can start attempting to tune next week
#89
I know how it is man, there's always something going on. No I don't have a build thread, it's literally going so slow no one would be interested. I've been slowly working on it and gathering parts for about a year and a half now. I'm a full time student and full time employee, working 3rd shift so I don't have much free time. Good news though I'm really close to having it running! Lol
#90
You should start a thread man. I would like to check it out
#91
Before I swap out my T4 plumbing in favor of a T6 to go the classic BW route, I want to try either the VS or ON3 88/83 (assuming they are the same turbo), or maybe even gran ON3's billet ball bearing variant of the 88/83....I am very very curious the difference in spool and back pressure compared to a 7875. I will be making a thread to document the differences in the upcoming year.
#92
I will probably baby step to the 84/75 billet ON3 first and see how it does. The 84mm billet comp. wheel is lighter than the cast 78mm. Should be able to spin faster and make more boost, spool quicker and flow more....but how much more, I havent seen any real world results yet from anyone when compared to the 7875
#93
if u just want to throw away money I'll take it 15 hours and 5 passes later this hunk of **** is trash fyi they dont sell rebuild parts for this turbo the guy at on3 pretty much said there paper weights when done that's y there 550$ also thisnis my second on3 turbo the 76mm was a piece of **** also so now i have a borg warner and its much better. Do what u want but im telling u my 88mm on3 is junk ill mail it to u if u wanna save 550 bucks to see for yourself friend
#94
all those T6 borg warners have a huge and oddly sized and proprietary turbine outlet flange right? like 5.75 inch or something stupid....what about the T4 housings...are they a standard 4 inch vband out flange?
#96
So I'm finally able to start messing with the car again. Had to move so that slowed everything down smh. Got my AEM wideband hooked up and I'm ready to start attempting to tune this thing or blow it up, which ever comes first lol.. Question, I'm going to drop some e85 in the tank so do I (using microsquirt) change the afr ratio value from 14.7 to whatever e85 is in the required fuel calculator and target the same afr's as if I were tuning for gasoline or..?? I did some reseatech but I'm still unclear
#97
#98
Ok thanks!! So I entered 9.765 in the required fuel and it rounded it to 9.8 So I'm assuming I'm Good to go ahead and start. Lets see what happens
