quick head stud question
First off I'd like to thank all you guys on here that know your stuff and share your experiences with everyone. As you can see I don't post on here much but I do read on here alott. Anywho, I'm doing my first ls turbo build, just a simple t4/7675 turbo, 5.3 l33 block along with dart pro 1 heads. Im using arp head studs and My question is are you guys torquing these to more than spec due to running boost? Also, are you retorquing them after so many heat cycles or miles? I did a search but only found threads on n/a stud torque. Any input is greatly appreciated!
Im at 80 lbs (with oil)on stock 3 layer gaskets. No issues-studs where still at torque when checked 1 month later. This was with AL and Iron blocks
Thank you guys for your replys so far. Sounds like ill stick to spec as suggested. So are arp head studs reusable then, like if I have to pull the heads for whatever reason? I ask bc I'm an automotive tech and I never reuse any torque to yield head bolts. Wasn't sure if these were considered the same?
Aaaand depending on what lube you use you will be using different torque values...
http://img.photobucket.com/albums/10...ARP_TORQUE.jpg
There are much better charts out there for that but Google wasnt playing nice with my tiny brain and lack of patience today...
