Machine a V band out of flange on truck manifold
I am currently building a twin turbo setup for my lamborghini diablo replica setup.
Still trying to nail down my turbo sizing.
Instead of welding a v band flange onto a cast truck or camaro manifold I wonder if there is enough material there to just machine the stock flange into a v band? I have 2 cnc mills and cnc lathe in my shop. Im all about going the extra mile.lol Im currently working on a billet oil pan for my 408 so i can put 7 quarts of oil in it. I dont like the pans on the market. I want a thicker gasket flange...etc
Realistically, if you're doing all that you might as well just make a set of headers..... Other than that I don't think that have enough consistent wall thickness to machine something nice to a nominal size.Could you make the shape? Maybe, but I don't see you being able to make it to a size that will have readily available clamps and stuff available
if he's got a CNC mill, its not much work to get it fixtured.
almost no work to find the center of the outlet.
and maybe 20 lines of g-code to write...
First one may take as long as welding, second one a couple min. If he's got a 5 axis mill, fixture time drops considerably.
the advantage here VS welding is it will be one piece and wont crack. 321 stainless is too expensive for my tastes to make a proper manifold that will last in a daily driver.
