Are these the Correct Injectors?
Old 01-28-2016, 07:59 AM
PCella's Avatar
Default Are these the Correct Injectors?
Alright guys I have spent a lot of time on this and think that I have it correct, but there is a lot of conflicting information out there as far as injectors and adapters.
I know that I want the 80lb Deka Injectors, I am just wanting to confirm that these are the correct ones and that I have the correct plug adapters.
This will be going on a 2005 5.3. The first link is to the injectors and the second to the adapters.
Thanks for the help.
http://www.ebay.com/itm/141645772723...torefresh=true
http://www.ebay.com/itm/LQ4-LQ9-4-8-...VVpjE-&vxp=mtr
Old 01-28-2016, 03:31 PM
RonSSNova's Avatar
Injectors are correct.
I like these adapters better. A little cleaner look.
http://www.ebay.com/itm/USCAR-EV6-Fe...dRjAkI&vxp=mtr
Old 01-28-2016, 03:55 PM
2005vetteTT's Avatar
assuming you have an EV1 connector, why not just pick up EV1 80lb? they are almost the same price.
http://www.ebay.com/itm/Siemens-Deka...ZThg3m&vxp=mtr
Old 01-28-2016, 04:22 PM
PCella's Avatar
Thanks for the response guys.
This is where all of the confusion comes in and I may be the only one confused, but I don't believe that I have the EV1, I believe that all of the 5.3s at least up until 2007 came with Delphi mini (multec II).
I could certainly be wrong, that is the reason this thread.
Old 01-28-2016, 04:35 PM
This is where all of the confusion comes in and I may be the only one confused, but I don't believe that have the EV1, I believe that all of the 5.3s at least up until 2007 came with Delphi mini (multec II).
Ahhh! I see. I went off what RonSSNova posted as adapters. That makes sense. I am not entirely sure what injector harness you have on that.
Old 01-29-2016, 11:44 AM
RonSSNova's Avatar
My apologies.
I'm not sure what the connector style is on the 5.3 harness.
My harness is from an LS1 Camaro.
Ron
Old 01-29-2016, 11:52 AM
PCella's Avatar
My apologies.
Ron
No problem.
I think that I am just going to get the connectors and splice them in to take out the guess work.
Old 01-29-2016, 02:00 PM
RonSSNova's Avatar
No problem.
Good. That's really the best solution anyway.
Ron
Quick Reply: Are these the Correct Injectors?
