Installed lsx motor with ls2 conversion, no start condition
Just finished installing my lsx motor in my 00 ta. I used an ls2 conversion kit for the knock sensors and the relocated cam sensor. Only other thing I changed was extended my map sensor wire which looks good. Car turns over, no start, appears to be no spark or fuel either. I have hp tuners but am not really familiar with it, can it help me diagnose the problem or does someone have any ideas what to look for?
Some of the cam extension harnesses need two of the wires swapped, from memory I believe it's the outside wires? I had to do this on my car years ago, good luck.
similar discussion at:
https://ls1tech.com/forums/pcm-diagn...-cam-swap.html
Might want to verify that you are putting the correct voltage to your cam sensor as well (5v or 12v)
You use +12v's to the cam, crank sensors-the LS2 uses 05v's to the cam, crank and pin A & C are swapped for the cam as opposed to an LS1, pin c on the cam conn. should read voltage for the LS2
I suspect the ECU is looking for a 24 REL and you have a 58, maybe one of the guys who do HP can shed some light on that
When I did a double roller setup my cam sensor was too close to the gear so it would not work. To get the car to start, I had to let it try a few times then cut fuel with the gas pedal and it would eventually start. I have now added a spacer and the car starts with no issue!
Not sure if this is the case for older cars but I have an 05 E40 ECU so that was the case for me.
