fuel pump(s) set up w/diagram
Old 02-01-2016, 03:03 PM
323z's Avatar
Default fuel pump(s) set up w/diagram
Hello I had question about my fuel set up, first a little about my set up.
Summit 5.3 block 243 heads. (CR-9.6.1)
K1 346 Crank 3.622 Stroke with 24X Reluctor wheel
Wiseco 3.800' Bore, 1.300, 3.622' Stroke,
6.125' Rod,1.0,1.2 2.8 XX ring package for boosted
Callies Comp Star 6.125' rods, 2.100' big end.
LJMS turbo cam 226/235 .605'/.610' 114+5
BTR.660' Lift Platinum Dual Spring Kit.
Chromoly One Piece Pushrods 7.400', ATI super damper. Precision 6266's with billet comp wheel, ported covers, and .82 vband. LS7 lifters, ls9 head gaskets, ls2 lifter tray Stock 799 GM rockers&peds. LS6 intake, LS1 throttle body., coolant cross overs.Millings oil pump.McLeod Twin Clutch Kit w/Steel Flywheel, 1200 HP, LS1-LS7
T-56 Magnum(2.66),HD 31T. JGS twin 40mm wastegates,50mm tial BOV. Truck manifolds.Holley HP, holley 160psi injectors.Holley fuel rails, holley fuel regulator
Drive shop axles-1300hp.Carbonetics 1.5 LSD. w/3.538 rear gear.
Ok here is a pic of my current fuel set up. fuel set up did support 730hp on c16 with 6(v6) 83#DEKA's Name:  fuel%20pump%20set%20up_zpsb3j6iyql.jpg
My question is. Is this enough fuel pump for e85? if not... Should I replace the 044 for a 4303? or just run 1 more 044?. Both 4303 or 2nd 044 would be on a hobbs switch.
Thanks in advance.
Old 02-01-2016, 03:33 PM
stevieturbo's Avatar
Your post seems to suggest a pair of 6266's. On that alone there isnt a hope in hell of a single 044 supporting the power a pair of those can make, unless you're going to run baby boost.
Your 83lb injectors also wont go that far on E85 either.
But then you arent stating your goals or fuel demand needs.
Old 02-01-2016, 03:42 PM
323z's Avatar
Thanks Steve for the quick reply.
LOL, no baby boost.. at least I hope not.
Sorry I don't think I was clear enough. I was running 6# 83lb injectors on a 3.5l v6 and I was getting 730 on c16 with 2 greddy 18g's with the fuel set up as on the pic.
I have since switched the 3.5l v6 for a gen3 5.3 and twin 6266's.
looking for 20-25lb of boost(1000rwhhp) on e85.
All the size lines are in fuel pump pic. And I now have 160lb holley injectors
Old 02-01-2016, 03:48 PM
323z's Avatar
I already asked a fellow ls1tech member/turbo builder/all around guy that knows his ****.
and he suggested I run 1 pump for start up and a 4303 with a hobbs. I know he knows his stuff but I figured I would ask more people and see what they suggested.
And since I already have it set up this way. I was seeing if I could just get away with either running and extra 044 or ditching the 044 altogether and getting a 4303.
Old 02-01-2016, 03:49 PM
You need more flow...end of.
Both in terms of the lift pump and main pumps/injectors.
It's quite common to return from the rails into the swirl tank, this means the lift pumps have less work to do.
ie you have 500hp worth of lift pump and an engine or main pumps pulling 1000hp of fuel....that swirl tank will be emptying fast.
So factor in how much fuel is leaving the swirl...just as much as how much needs to be going into it.
Injectors, may as well do something in the 1300-1600cc range and I'd be surprised if a single 4303 would safely do 1000hp on E85, but I'm sure people who have actually used them could comment better.
I doubt a pair of 044's would either, and some say they may not be happy long term with E85.
Old 02-12-2016, 11:15 PM
323z's Avatar
I appreciate your comments Steve.
I changed some stuff around, I was able to get a 485 wally into my hanger. I haven't bought the Magnafuel 4303 yet but gonna pull the trigger on that in the next week or so. Plan is to run the 4303 on a 4psi hobbs switch. Will this get me closer to my goal of 1000whp?
Old 02-13-2016, 03:42 AM
A Shown an 044 + 4303 should easily do 1000hp for you.
I think I'd prefer a -8 line for the 485 into the surge tank, but it's maybe not essential
Also some do prefer to run the rails in parallel, rather than in series, but either will work fine.
Quick Reply: fuel pump(s) set up w/diagram
