Afr for e85
You don't have to change anything...you can still target 11.5 on a wideband setup for gas when running e85.
Lambda 0.780
e85 7.613
gas 11.466
Are all the same thing
Lambda 0.780
e85 7.613
gas 11.466
Don't take this the wrong way, but if you don't know this and you're doing the tuning you should stop. Go read more on the hptuners forum and in the timing section. Or go pay someone so you don't hurt your engine/self/someone.
If you aren't using and dont plan on using the o2's then I don't think it matters if you change the stoich or not. Your boost enrich and power enrich table still gets set to the same value no matter what the stoich is set at.
