Car has the sniffles
Old 02-08-2016, 07:39 PM
redsscamaroboy's Avatar
Default Car has the sniffles
Ok guys I'm looking for suggestions .
My 98 Z28 is definitely under the weather, I need to find a shop that can sort out and diagnos why the performance is off the mark. ( by a lot)
Mods are in the sig .
I have a dyno sheet that shows it has put down 540/440 on a Mustang dyno with 6 psi of boost thru the old TH400 and now has a 4L80E in it.
I bought the car and took it to the track and ran 11.4@120 , car ran neck -n- neck with a bolt on 14 SRT8 Challenger on the highway ( friends car that dyno'd low 420's)
It just don't pull on the topend , it should be a beast up top but it just lays over.
I was told it has 2 pumps in the tank but have not verified that.
So I'm looking for a place around Grand Rapids,MI that is good with boosted LS1's. Let's hear your ideas. Thanks in advance.
David
Old 02-09-2016, 06:05 AM
LS1-IROC's Avatar
Here I thought I was the only one running around in the tiny town of Lowell with a boosted LS1..lol
Do you know who tuned it?
Old 02-09-2016, 06:48 AM
Tuckin15s's Avatar
I'm no help but it's nice to see some local guys on here!
Old 02-09-2016, 07:13 AM
L92 OLDS's Avatar
David
I'm also from the Grand Rapids area. The guy to go to for dyno tuning is T.J at Baker Engineering. Give him a shout. He's a busy guy but definitely knows his way around GM systems.
http://www.bakerengineeringinc.com/
Old 02-09-2016, 11:04 AM
I know the original owner ( was my friend , but has passed away) took it down south somewhere to have it tuned. Possibly EPP?
And that's where the 540/440 numbers came from.
What are you driving around Lowell? I haven't run into too many Monsters on the streets yet . Seems like there is a good amount of Trans Am's there for sure.
Old 02-09-2016, 11:59 AM
I appreciate the heads up.
Old 02-09-2016, 12:04 PM
rpturbo's Avatar
T.J. is on here, and built a bad *** turbo S10 some years ago. I am not sure if he still owns it or not. It was his high school truck, and he had it for sale for a minute, but I think he kept it. By that truck, he certainly knows his way around LS's.
Old 02-09-2016, 01:45 PM
LS1-IROC's Avatar
+1 for TJ as well. He tuned mine and hopefully will be tuning my new set-up this spring as well.
As far as your problem...I would first check to see if you are running out of fuel if it's laying over on the top end. Does the car have a wideband in it?
Old 02-09-2016, 02:10 PM
Tuckin15s's Avatar
Yeah his screename on here is hellbents10. Unfortunately his black turbo truck was sold last summer, He has a z06 now.
Have you checked for boost leaks or anything?
Old 02-09-2016, 04:27 PM
Steady boost, no leaks .
I have a wide band in the box in my toolbox.
( spring project ).
Car used to lose traction at 70 on the highway. Now it just makes noise and doesn't seem to pull .
I did fuel filter, plugs, oil change just because I was under the car.
I want to have a experienced tuner work on the tune, it was originally done back in 2008 . I would like to swap the pulley ( it has a custom made pulley on it ) to put the F1A back in a efficient operating rpm .
A full weight car with 540/440 rwhp and this much suspension work should easily pull a low 10 in my opinion.
It didn't matter if I rode out 3rd gear or shifted to 4 th , 120 mph was all it would pull.
Time to look into what TJ thinks. Thanks guys.
Quick Reply: Car has the sniffles
