rear mount crankcase vent pcv
Im running a single rear mount turbo on a stock motor 8 psi, just wanted to know whats needed on the pcv part of the system.
Whats the easiest simple system that works? I have a breather on the oil filler and a vented catch can yet to be installed.
Since you are rear mount turbo and cant run a line from the turbo inlet easily or effectively (too restrictive with that long of a run), I would vent both banks into an open catch can with a breather on it.
Otherwise I would run a filter on 1 valve cover, and a line off the other valve cover into a catch can and dual outlets with checkvalves...1 to the intake manifold and 1 to the turbo inlet. This gives you evacuation under vacuum AND boost. Works fantastic.
