Boost reference truck rail?
Old 04-21-2016, 02:55 PM
vic_dahn's Avatar
Default Boost reference truck rail?
Quick question, can I boost reference my stock early truck style fuel rail?
I am running 78% duty cycle on deka 80's with no boost ref @650whp now 11.9A/F I may step it up this year and I dont want to buy new injectors.
Thank you
Vic
Old 04-21-2016, 03:49 PM
408GT's Avatar
Yes you can. What fuel pump(s) do you have?
Old 04-21-2016, 04:43 PM
vic_dahn's Avatar
Bosh044 1/2 line both ways
Old 04-22-2016, 09:20 AM
stevieturbo's Avatar
What is your base pressure now ? And presumably you have some sort of regulator already ?
Exactly what do you have ? a schematic always helps but there shouldnt be a problem
Old 04-22-2016, 09:54 AM
vic_dahn's Avatar
Its a factory early truck rail with the stock regulator with no line(ref) hooked up. It has worked great for the last 3 years but I was just asking if I can boost reference the stock regulator. We checked it and its running 50 Psi
exactly= Bosh 044 1/2 aluminum hard line feed and return. Massive Jegs fuel filter
No schematic needed
Old 04-22-2016, 10:05 AM
If there is a regulator with a reference port on it, then yes.
Old 04-25-2016, 11:18 AM
vic_dahn's Avatar
Sweet! Thank you for your advice!
Quick Reply: Boost reference truck rail?
