How much boost can a aluminum gen 4 LS2 handle reliably?
Gen 3's aren't as beefy as gen 4's.
That's awesome, especially on pump. I'd be very happy if I could make those numbers and live that long.
I'd say his had to be in the tune then from everything you guys have said. That sucks because I guess I need to have mine looked at then.
This will be my third year running like this. No meth, just pump gas from whatever I can find really. Buddy with his Camaro runs methanol with the higher compression and tends to get his gas at the premium stations like Shell or Chevron. He pulled it out this year after a couple year hiatus because he was tired of dealing with the M6 and breaking/noise from it. Why I plan to keep mine just a street toy, already has enough noise that echos in being an fbody.
Car started life at 305/313 rwhp so can say I'm pretty happy with the return in power out of the sbe at this point
Restricted User
Ryan tuned my car as well. This year I am making the switch to MS3 though.
Yep. This thing has seen 600+ rwhp since it's been in my car. Has had a couple different cams and going on the 4th turbo, lol. With the last turbo, cast wheel S480 92mm 1.10 ar it made 730 rwhp and we stopped there. New turbo is a billet S480 96mm 1.32 and I plan on pushing it harder this year. It will go 150+ in the 1/4 this year easily. It would have done it last year but had some issues at the end of the season with the oil feed at the track and only made two passes.
I'd be happy with 600-650rwhp if it could stay together for a couple years until I can figure out what route I wanted to go in. Not sure if I will keep it there, or forge it to make some big power. So if anyone has a gen 4 crank, pistons, and rods laying around that they want to sell, I'll buy them lol
I just got into fi over the winter so I'm trying to learn as I go. I originally just planned to keep it sbe, so I'm just running the tc78 and I'm not sure how much power I can make with it. I wished I had went a different route with it now. I'm just trying to do this so it will last until I k know for sure what I want, but still be happy with it while I'm doing it.
Restricted User
#34
My main concern was the block itself since it was aluminum.
#36
Realistically, I don't see myself wanting no more than 750-800rwhp. For now I'd just like to run it between 600-650rwhp on pump it it's possible. I just want it to live and not have to worry that it's at it's breaking point, providing the tune is in check.
#37
Restricted User
Yeah I said earlier that it was my fault for saying that, sorry . For some reason, I had it in my mind that some early ls2's came with gen 3. I think I had it confused with the early 04 6.0? Didn't those have gen 3 and then change to gen 4 later that year?
#38
Idk what I'm thinking about then. What 6.0 came with gen 3 rods? That 6.0 I'm looking at has the gen 3 rods in it?
Edit: just saw you said aluminum, I meant iron block 6.0
I want the aluminum ls2, but until I asked on here, I heard they didn't handle boost well (block).
#39
Congrats! That's some pretty good numbers.
Pm sent. I ll have a set of ls2 piston n rods forsale-12k miles from 06 gto, completely stock!
#40
I'd run the LS2 the way it is with the stock 243 heads. It seems to be much stronger than the LS1. Many people with corvettes make 600+ out of their stock LS2s with boost. The higher compression will keep it "peppy" while your out of boost and make it more fun to drive.
