Pros and Cons to WG on Turbine Housing?
I thought we had a thread on this already but I can't seem to find it. And with the exception of Matt's Sloppy Colorado, a thread at Yellow Bullet, and some import crap, I can't find hardly any info on the subject. I'm just looking for realistic pros and cons.
I have to redo my crossover for my nbs silverado (gate in co) because the jackazz I bought it from thought it be cute to hack off the gate flange before sending it to me. So long story short, I have to redo the crossover and weld on a gate flange regardless. I just thought it would be a good time to consider it. The only down I can see is cutting a hole in my new T4 s475 and that may hurt resale down the road yet I don't plan on selling it no time soon. On the plus it seems to have the potential to control exhaust much better than in the co. Give me some input guys.
RyanR
RyanR
Downside is the fact you're having to weld to the housing which has the potential to fail.
Other than that, if it fits and works for you, just do it.
Just do it close to the flange as opposed to deeper in the scroll as discharging air too close to the turbine might make it less efficient at actually driving the turbine ?
Thanks for the reply. And yeah, I guess you're right and I should just man up and get on with it.... just kinda spooked because it's uncommon. I know of 2 different guys that are extremely good at tig welding (unlike me) that should be up to the challenge. As far as a failing point though, is it really any different than any other position possibly failing? Seems like a possible risk no matter where it's mounted to some degree.
Value of the turbo.... I understand that but I can buy a new housing for $175 if something ever happens and I honestly didn't buy it to resale it. The functionality of it outweighs the dollar value imo.
I ordered a new gate flange last night so hopefully I can make some progress next week.
just a thought as I am no expert on turbos...wouldn't adding the WG to the housing as being discussed here be the same as a turbo with a built in WG?
So far, from what I read, it seems to be a very effective place to add the WG. Looking at cut aways and drawings, the internal WG is ported just past the flange before the scroll of the housing starts.
Im about to do this. My precision 46mm gate has a 1.88 inch inlet to be used with 1.5 inch pipe dimensions, rather than 1.75 tube, so I think that will be nice to use a thicker material like the turbine housing to weld it together. Just cant decide if I want to weld stainless pipe to it or mild steel pipe to it. I researched it heavily on welding forums and it is advised to use a high nickel content filler rod like 309 rod (if I recall). Pre-heat, weld, and cool slowly. Only thing I dont like is not being able to use my turbo blanket, so I will probably have it ceramic coated after I am done.
my evo has a fp green htz with the wastegate 90° off the side of the inlet of the turbine. it appearsto be a very inefficient spot and FP warns it wont go below 20psi but ive run 14psi. its a pretty efficient wastegate location by my experience, but you generally have to ramp out wgdc as rpm climbs at lower boost levels. as you raise boost the wgdc will go level then invert to a positive slope.
