Need some advice
Old 05-26-2016, 09:09 PM
Rscaamaro's Avatar
Default Need some advice
What's needed on my 86000 mile ly6 6.0 motor to survive boost. Trying to be around 800 to 1000 hp turboed.
Rods, pistons needed?
Old 05-27-2016, 09:33 AM
Restricted User
JoeNova's Avatar
Boost. Lots of it.
Old 05-27-2016, 09:36 AM
svslow's Avatar
Boost, solid tune and good fuel.
Old 05-27-2016, 12:48 PM
Rscaamaro's Avatar
I was thinking rod bolts and filing new
rings, cam valve springs
Old 05-27-2016, 12:53 PM
Restricted User
JoeNova's Avatar
Rod bolts? LOL.
Filing rings isn't a bad idea. Anytime you plan to run high boost on pump gas, opening up the factory rings is a good idea.
Cam and valvesprings, again not a bad idea. Cam surprisingly doesn't have nearly as much effect on power potential as it does on behavior. And valve springs for boost are a good idea for a high mileage engine because over the years they soften and cause float.
Old 05-27-2016, 03:11 PM
Rscaamaro's Avatar
Originally Posted by JoeNova
Rod bolts? LOL.
I am new to the turboed ls motors, just don't want to have engine failure, so rod bolts will be fine
Old 05-27-2016, 07:38 PM
Restricted User
JoeNova's Avatar
Power has absolutely zero direct effect on rod bolts, so unless you plan on shifting at 7600 RPM, you're not going to need them.
Most of the time they do more harm than good. If I had a dollar for everytime someone spun a rod bearing with ARP bolts in their stock rods, I would have a full sponsorship.
Old 05-27-2016, 08:01 PM
Rscaamaro's Avatar
What turbo seem to be working on 6.0
Old 05-27-2016, 08:06 PM
Restricted User
JoeNova's Avatar
Go read other people's builds and do some research....
Old 05-27-2016, 08:12 PM
Rscaamaro's Avatar
That's for the info
Quick Reply: Need some advice
