NEED HELP car cuts off off around 5500 rpm
Old 07-14-2016, 12:34 AM
fserrano84's Avatar
Default NEED HELP car cuts off off around 5500 rpm
Car cuts out around 5500 rpm in first and second gear only motor does not shut off or anything It just gets to 5500 and feels like I let off the throttle Car is a turbo car on e85i have had this issue on last build which was mostly stock lq4 then I rebuilt it and upgraded several things I was thinking it was the tune since I tuned it now after the new build i had it tuned professionaly and stills does it only in 1st and 2nd gear 3rd has no issues car is a manual transmissions any ideas on what it could be
Old 07-14-2016, 10:25 AM
svslow's Avatar
Which ecu, spark plugs, cam valve springs?
Old 07-14-2016, 10:50 AM
fserrano84's Avatar
Stock ecu br7ef gapped to .024 also tried .028 btr dual valve springs with titanium retainers good for .660 lift
235/231 | .635"/.605" | LSA114+6
Old 07-14-2016, 05:39 PM
Old Geezer's Avatar
If you tuned it, do you have the tune and log[s] to post?
Old 07-14-2016, 06:05 PM
fserrano84's Avatar
Yes I can post that up I'm going to try and log it tonight is there anything specific to be logging
Old 07-14-2016, 08:18 PM
3 window's Avatar
Fuel slosh? Harder acceleration in first and second than in third. Run the rpms up slower in first and second and see if it does it. Log fuel pressure.
Old 07-14-2016, 08:45 PM
fserrano84's Avatar
Sounds very likely put could it still do it with a full tank. I cut up the stock bucket to fit dual pumps
Old 07-14-2016, 08:59 PM
3 window's Avatar
Not likely with a full tank. Are the pumps bottomed out in the tank causing a starvation? Figure it'd do it all the time then, but anythings possible.
Old 07-14-2016, 09:06 PM
fserrano84's Avatar
The bucket itself is bottom out not sure is it suppose to or not but the pumps I don't think they are I need to double check them too. My wideband does read extremely lean right after when it happens
Old 07-14-2016, 10:04 PM
3 window's Avatar
Monitor pressure when it does it. If the pressure stays up, could be you need more fuel in that area of the tune. But again, wouldn't explain why third gear is unaffected.
Old 07-15-2016, 08:00 AM
Old Geezer's Avatar
3rd gear is a lower rate of acceleration..
Old 07-15-2016, 10:55 AM
fserrano84's Avatar
its been raining so i have to wait to get a log but heres the tune file
File Type: hpt
Old 07-15-2016, 11:33 AM
3 window's Avatar
Mentioned in post #6
Old 07-19-2016, 10:30 AM
93camaro_zzz's Avatar
What does the AFRs show when it breaks up? Simple stuff first: make sure all the grounds are tight.
Old 07-19-2016, 11:58 AM
fserrano84's Avatar
afr is all good when it happens unless theres a lag in the wideband reading on the scanner and it also seems to be an intermitten problem now
i dont have a way to check fuel pressure
Old 07-19-2016, 12:01 PM
fserrano84's Avatar
go to 4:30
File Type: hpl
Old 07-19-2016, 02:53 PM
fserrano84's Avatar
I think I finally found out what it was and it was my own stupid fault. I will post more later I have to go to work
Old 07-20-2016, 07:53 PM
V-10 Killer's Avatar
So, what did this wind up being?
It's got me curious because I noticed mine seems to studder around 6200 and 10 psi.
Old 07-20-2016, 09:24 PM
fserrano84's Avatar
I installed a n2mb 2step/wot box and didn't mess with the setting on it thinking it wasn't activated. So every time I was about the go for the next gear I would put my foot on the clutch pedal and the switch on it was set extremely sensitive and would activate the no lift shift feature with the slightest of touch on the pedal. then it would cut off the ignition
Quick Reply: NEED HELP car cuts off off around 5500 rpm
