2 Port JGS 60 BOV used to regulate boost???
I see the new 60mm BOV has two vacuum ports that was designed for blower guys to regulate boost. Has anyone used one to act as a wastegate AND BOV?
I have a blower coyote that I installed a 16psi pulley and I am going to regulate it to 10-11psi to gain a bunch of mid range power.
I'm more interested to see if anyone has done it or how exactly it would work.
There is no way an MBC will work for this.
You need an electronic controller. It doesnt need anything fancy though, but ecu control is best and will give the most options
FYI, I accidentally hooked mine up wrong and put the manifold reference to the lower port when I dynoed my car on wastegate only and couldn't get over 6.3 pounds of boost. I realized my mistake and switched the ports while still strapped to the dyno and went right to 12.1 on the next 2 pulls.
My BOV had the medium spring in it BTW.
