dual waste gate/ solenoid plumbing
Quick sanity check...With the above diagram if i am running a single turbo with two waste gates what is the best way to plumb it? I would assume just y the gates together going to the solenoid and split them from compressor to the gates. Basically y both lines. And i would only need one dome pressure sensor on one of the gates right? Thanks in advance.
Follow the instructions of whatever controller you are using. There is no generic "best" given the many configuration options that exist.
I'll still never get why the US systems need to use 2 solenoids to do the job of one.
This is the diagram for the Holley boost controller solenoid. They don't have a recommended setup for dual wastegates in their instructions.
This issue confuses me to no end. You tee the compressor discharge to the bottoms but you also need for the tops (pressure source).. not using co2 or anything... now you tee that compressor discharge 3 times? Is there someone that has the holly efi ecu running 2 3 port solenoids and dual wastegates?
