Turbo 6.0 Monte Carlo SS goes 10s @ Mile high
Old 07-23-2016, 08:11 PM
Jose93z28's Avatar
Default Turbo 6.0 Monte Carlo SS goes 10s @ Mile high
This is my friend Davids Monte Carlo SS turbo 6.0 ly6 running 10.4 @ 133mph
At Bandimere Speedway track is over 5800ft and DA that day was around 8500ft
He still has a lil room for improvement and looking for lower times, what you guys think?
Old 07-23-2016, 10:41 PM
3 window's Avatar
Can't tell if it's on a slick or a radial, but either way, you need to get that porpoising out of the car at the hit. Try stiffer compression on the rear shocks and slow the front end down. It's bangin the tire pretty hard and you can see it crush the sidewall and spring back up. Other than that, it looks good.
Old 07-23-2016, 10:59 PM
Tomhames's Avatar
What's the build consist of? Car looks great
Old 07-24-2016, 02:48 AM
Nitroused383's Avatar
It looks like the rear end bottomed out or hit the bump stops pretty hard on the launch?
Old 07-24-2016, 07:47 AM
Bad Apache's Avatar
Opinions are like butt-holes, everyone has one and most of them stink. LOL
That being said I'll throw mine in here too. I watched the video frame by frame. It doesn't appear to be squatting or lifting, simply hitting the tire hard. The front end is rising too quickly and hitting the stops causing the porpoising. I would stiffen the front shock extensions and up the rear tire pressures a 1-2 psi and video it again. Looks great otherwise! Congrats!
Old 07-24-2016, 11:28 AM
Jose93z28's Avatar
Lol yeah amen to that, he is going to run it at least once before the season is over but ill let him know the pointers you guys are giving him and we'll see how it does then he still needs to do a couple things before going back
Old 07-24-2016, 11:30 AM
Jose93z28's Avatar
6.0 LY6 with a ls3 top end isky cam, jakes 4l80e tranny with a transbrake circle D converter, T76 turbonetics Turbo and custom manifolds
Old 07-24-2016, 11:45 AM
3 window's Avatar
If you just want cheerleaders and not opinions, don't ask in the thread "what you guys think?" Try
Old 07-24-2016, 11:47 AM
3 window's Avatar
Old 07-24-2016, 11:57 AM
MY_2K_Z's Avatar
Screw that I wanna see some cheerleaders!
Old 07-24-2016, 02:06 PM
topbrent's Avatar
Is there a build thread anywhere on this car? Very cool.
Is this combo using a cam spec'ed by Stock48?
Old 07-24-2016, 06:56 PM
Jose93z28's Avatar
Thanks for the comment I do take any input into consideration ill let my buddy know what you said so he can look into it and make some changes on the car(not looking for cheerleaders)👍🏽
Old 07-24-2016, 07:03 PM
Jose93z28's Avatar
My friend is not on this Forum so no build thread sorry, but yeah his cam is specd by Stock48
Old 07-24-2016, 07:22 PM
Jose93z28's Avatar
I think it was just his tires getting traction that made it hit like that but he is looking into it to make the changes he needs before he runs it again
Quick Reply: Turbo 6.0 Monte Carlo SS goes 10s @ Mile high
