tossing a simple turbo setup on my wifes 2007 WT silverado
Old 07-26-2016, 09:34 PM
Moderator
denmah's Avatar
Default tossing a simple turbo setup on my wifes 2007 WT silverado
ya know, because, it doesnt have one, so ones gotta go on
2007 totally stock 4.8 WT 2wd
doing a 228/230 trickflow cam
pac 1218 springs
7065 turbo on a KB racing manifold, single 44mm gate on the turbine
3 inch air to air intercooler, 80lb injectors in the stock intake, 450lph in tank pump, converting to 2Bar OS and trying a duramax 3.3bar Ebay sensor
installing 4.56 gears, exhaust dump valve and connecting to stock exhaust for stealth manuvers.
Old 07-26-2016, 09:41 PM
3 window's Avatar
Get it on the pump! Let's go slow poke!!!!
Old 07-26-2016, 09:56 PM
gametech's Avatar
I'm onboard with all but the 4.56 gears. I don't understand that choice.
Old 07-26-2016, 09:57 PM
ElQueFør's Avatar
Interested in your choice of 4.56 gears? Trying to sort out a prospective turbo 6.0 setup and have been told to ditch my 4.88 gears. 60e? tire size?
Old 07-26-2016, 10:13 PM
Moderator
denmah's Avatar
Well
It has 31 inch tall tires stock, that and 4.56 gears at 6500 in 3rd is like 130 wich is plenty fast for this
It'll make that gutless 4.8 feel good out of boost in this 5000+ lb truck and take some load off the 60e pushing the whole setup around.
We don't plan on land speed racing it so I ask, why not 4.56
Old 07-26-2016, 10:23 PM
ElQueFør's Avatar
Interesting. Makes me wonder if 4.88 wouldn't be too bad in my setup with 29" tires, the deep MN6 T56 gear spread, and it being a heavy *** truck.
Old 07-26-2016, 10:37 PM
66Chevellelq4's Avatar
Did this truck not come with dod and vvt and all that crap?
Old 07-27-2016, 02:23 AM
8 Second Truck Club
Blown06's Avatar
That truck looks like it is in pretty good shape. How many miles are on it and what did you give for it? Don't mean to be all up in your personal business so ignore if you don't want to answer. I'm just curious what kind of money a truck like this would bring.
Old 07-27-2016, 05:13 AM
Moderator
denmah's Avatar
Correct 4.8 Doesn't have all the bullshit you have to remove !
Moderator
denmah's Avatar
It took us a while to find one this clean
I think she paid 9k
92,000 miles super clean inside and out
Old 07-27-2016, 06:54 AM
lxcoupe's Avatar
Why such a big cam?
Old 07-27-2016, 08:47 AM
Moderator
denmah's Avatar
because all else fails wanted to have it lump a little, the 216 is barely larger than stock, i also agree its a tiny large but oh well, its fun to experiment
Moderator
denmah's Avatar
i figure no matter how backwards it is we will hit 400-450 tire easily
Old 07-27-2016, 09:13 AM
Restricted User
JoeNova's Avatar
I've started using Howards cams over the Trick Flow stuff (and I've used a lot of the 2 Trick Flow cams). They're the same price as the 228/230 and you have a LOT more options. There are probably 6 cams in between the 216/220 and 228/230 that ship same day from Summit.
I'm interested to see how this turns out. A cam that big on a 4.8 with a turbo is either going to make great top-end, or fall hard on its face depending on backpressure.
Old 07-27-2016, 09:51 AM
aknovaman's Avatar
We run a very similar cam in my buddies 48L SAAB AWD and it runs great in a heavy vehicle with good driveability and 113 LSA.
Old 07-27-2016, 10:33 AM
Nali6.2's Avatar
ive wanted to put a kit on my 11 sierra denali but afraid to grenade the trans lol
Old 07-27-2016, 10:36 AM
aknovaman's Avatar
You need a different trans builder.
Old 07-27-2016, 01:25 PM
Moderator
denmah's Avatar
yeah i have used it on turbo 6.0 and 5.3's and i like it alot
Old 07-27-2016, 01:41 PM
Forcefed86's Avatar
Can also grab the low lift cams with moderate duration and tight LSA. They retain low overlap to keep turbo stuff happy and sound mean.
Edelbrock 2215 cam was super responsive on my 4.8 turbo 280z and the idle sounded mean.
https://www.youtube.com/watch?v=hXrb...ature=youtu.be
Howards makes a LS GM hotcam clone that I'm trying on the new build, It's low lift as well and they sound aggressive in the youtube vids.
Old 07-27-2016, 01:52 PM
Moderator
denmah's Avatar
yeah i have seen the howards camshafts they really interest me, i will shelf that edelbrock cam part number for a rainy day dude, thank you haha
Quick Reply: tossing a simple turbo setup on my wifes 2007 WT silverado
