On3 7876 vs pt7675.... The dyno results (video inside)
#61
What's "kind of wierd" about it? The op didn't skimp out on his turbo selection the first time and had an issue with the unit. He found an alternative turbo that fits both his budget and needs for his "street car". If he's happy 👍
#62
7 Second Club
I'm certainly not salty, as I have no reason to be. It's just that your reasoning is bizarre, and that's putting it mildly. I could see if testing was done once in august at 105 degrees at 12psi, and the other in January at 8 degrees and 25psi....and on different dynos.
#63
I'm sorry you don't understand how this stuff works but to call it bizarre is funny and just because you think it should be the same doesn't make it so. When was the last time this dyno was calibrated? When was the last time the weather station sensors were cleaned out to make sure they were accurate? How do you even know that the settings were the same on this dyno from before to now? You do realize this is a user configurable dyno right? And all of that is ignoring the FACT that the dyno correction factors are not accurate on a boosted vehicle. My reasoning is bizarre? No, it's called real world experience of using multiple types of dynos every day.
#66
Thanks
Yes, it's a 6 speed....still on the 10 bolt. And I do drive to the track.
#68
My calculator shows 60.9 hp delta uncorrected, and 61.8 corrected.
Also shows that the correction factor is the same until the third place after the decimal point (1.07979 vs 1.07556) The difference in correction factor between the two days is less than 4 hp.
I know you've said that correction factor is useless on turbo cars, but it does show us that the weather was basically identical on the two days.
With the test on the same equipment, in the same weather, it really only leaves the operator purposely falsifying inputs on only one of the runs....
#69
What I'm curious about is what brand and model of turbo is appropriate for a built ls2 in this case? Meaning his precision was obviously **** and he wanted to replace it with a like sized turbo and the only other one I can think of is the turbonetics 7875. Is that what would the two in here mentioning the on3 not being good enough would use instead?
#70
#71
awesome, glad the china turbo is working out for you! i put in my order for a 7875 from VS racing last week. already seen many success stories/dynos, but always nice to see another!
#72
Great results game! Glad to see a comparison of these turbos.
Since everyone is knit-picking the **** outta these results, I'll throw in a couple wild cards.
You're down half a pound of boost from the PTE with the new turbo - there's 10rwhp or so. You're also down nearly 500 rpm than the PTE number. There's a some power on the table there as well. So you're likely within 10-20 rwhp of the PTE at peak hp with these two setups being as close to identical as possible
#73
Ill be curious to see how long it survives as well. a buddy of mine ran ebay turbos on his vw for a while and at low boost setting they would last but when he would crank it they would last a couple hundred miles before they ate themselves. he now runs a precision.
#74
7 Second Club
No offense but did you even look at his graph? Obviously not a dynojet.
#76
I'm saying it's BS because it's not just 750 but how much less power there is across the band. If it's 750rwhp from 2k to 6500rpm flat then sweet! But it barely peaks there and dives off like it's in the Olympics. I'm saying it's BS because what was claimed is false based on the data. It's a cheaper turbo and produced significantly less power across the board, HP and TQ. Also the trap speeds don't back up the original HP claimed which makes me question the dyno used.
If he's happy with it then cool, just don't try and claim the turbo is something it's definitely not. If the power loss is worth $1k then cool. If not then upgrade. It's that simple.
#77
I've posted enough 1k rwhp plus dyno graphs that I don't need your approval.
#78
#79
I have no idea if this guy is telling the truth or not, but don't be surprised if you never see a graph. You're likely to receive more evasive....vague claims as to his many accomplishments. I see it like this.....post up......or shut up. And I'm probably out of line, because this wasn't directed at me....but just needed to say it.
#80
Man, lots of talking in here. I just want to say that car is completely badass to me! Job well done. People get lost in the glamour of crazy builds and fail to see a sweet street car here. Awesome ride.
