Holley boost control-co2 or compressor air?
very very very rudimentary.
There are various issues that could affect how much you apply to the top.....yet nothing to do with backpressure.
if you are not trying to run a light spring with a ton of boost i see no reason to go co2.
or if its a 100% track car i could see some control advantages with co2 but not on a street car
With normal manifold air, this low setting is dictated by spring pressure, with high pressure air you could just blow the gate open against the spring.
The benefit some say for Co2 on a street car is effectively you can blow the gate open at zero boost...so that gives you the best chance of running the lowest boost possible for your system which gives more scope for ramping boost with speed etc to assist traction.
#33
When boost control is active it will use air/gas, when it isnt, it wont.
#38
Originally Posted by 98Camarod
Holley uses duty cycle %, so how would you get back pressure out of that or am I missing something?
Also, make sure that you leak test it to maximize the life of the co2.
#39
and here I have been jamming the gate open with wire ties, loaded with flashpowder squips each set to detonate in sequence thereby releasing the gate spring more and more as speed increases (not really!)
