1018hp Twin Turbo 57 Buick build thread "The Jackal"
Old 09-13-2016, 11:18 AM
  #41
slocaddy's Avatar
Originally Posted by TrickrTreat
Took the factory tank out and had Mike Hall at Halls race cars do the sump. -10 feed -8 return. Wasn't loosing the stock gauge or trunk space.
I like this.
Was originally my plan for the caddy, didn't want to lose the behind the liscense plate fuel fill ,and like you i didnt want to lose trunk space for as low as I want it to be , I figured I'd be pretty pissed if I scraped off fuel lines and pumps.....
Old 09-13-2016, 02:51 PM
  #42
TrickrTreat's Avatar
Originally Posted by slocaddy
I like this.
Yup. I couldn't lose that trunk space, factory gauge or my bumper fuel fill.
Actually playing fuel games today speak of the devil.
Old 09-27-2016, 10:24 AM
  #43
Got the cold side done. Thought this was a cool shot.
Old 09-27-2016, 03:55 PM
  #44
408GT's Avatar
Good looking build!
Old 09-27-2016, 07:12 PM
  #45
IH8FORD's Avatar
Loving the Build, Great work! I recently picked up a 1957 Chevy 2 dr hard top that I plan on doing a nice turbo build. Im finishing the final touches on my 2004 cts V turbo build now.
Old 10-05-2016, 04:16 PM
  #46
Originally Posted by 408GT
Good looking build!
Thanks guys! I'll have to check that build out!
Old 10-05-2016, 04:18 PM
  #47
Got my Michigan Motorsports coil relocation kit in today, quality looking pieces right here.
Old 11-09-2016, 02:53 PM
  #48
Haven't updated lately. Been busy with work.
Got the coil packs mounted.
Also the 98 windstar thermostat housing and 04-05 cts-v thermostat worked like a charm. I did notice extra resistance from the second disc compared to the stock fbody so we'all see how that plays out.
Old 11-09-2016, 02:56 PM
  #49
Clear coated the Highram and bolted it down. Got the 95lb injectors and rails on. Also because of clearance issues with the aftermarket valve covers I bought I just shaved and smoothed the stock valvecovers. I actually like them A lot. Lol
Old 11-18-2016, 11:21 AM
  #50
IH8FORD's Avatar
looks good! cant wait to see it finished.
Old 11-28-2016, 06:27 AM
  #51
Radiator, Fan shroud an core support "all in one" brace I made. It's no BMR piece but it didn't come out to bad if I say so myself.
Old 11-28-2016, 06:32 AM
  #52
Oil feed to turbos -4 to -3 split. Used a NX fitting. Split to (2) -3 vibrant lines.
Old 11-28-2016, 07:40 AM
  #53
ScottyBG's Avatar
Your motivating me to finish up my Buick. Been giving more love to the Camaro and Oldsmobile lately. I put my Buick on an Art Morrison frame, and put coil overs and big Wilwood's on each corner then let it "rest" and my pocket book for a while.
You should take it to the Buick meet in Bowling Green KY in the fall. I've thought of doing mine in an '80s GN, black on black color scheme. Like what the GNX would have been if born in the '50s
Old 11-28-2016, 03:17 PM
  #54
Narxoleptic's Avatar
wow!! That is awesome!! subscribed!!!
Old 12-23-2016, 11:47 AM
  #55
Sorry , been full force on getting it fired up and drivable. Here's a video clip of the first start up. Damn LJMS custom cam is rowdy sounding!!!! He said it would be though.
Old 12-23-2016, 11:49 AM
  #56
Backed it out the other day after letting it run for a bit.
Old 12-23-2016, 11:50 AM
  #57
Took it out for the first drive this morning!!!!!
Old 12-23-2016, 11:53 AM
  #58
No fenders were harmed in the building of this car.
Side note though. It's way too loud for me. Absolutely running a full 3 inch exhaust with cutouts under neath.
Old 12-23-2016, 11:59 AM
  #59
And for those of you wondering about the WARR throttle bodies. It took the stock sensors perfect. I checked the throttle blade screws, they had thread locker already. I turned the idle screw a little so that it just touched the stop then a touch to crack the blade open. There is absolutely no hanging of the blade. Damn thing starts and idles perfect. It's the 92mm. Just figured I'd share my experience.
Old 12-25-2016, 06:01 AM
  #60
forcd ind's Avatar
We need an idle vid, lol
Where did you mount the fuel pump-as you have prob read, some guys had trouble with the 1800-i have the little brother 1400, I mounted it right in front of my tank, also sumped, so the fuel will gravity feed to it all the time.
I also found a ball valve, no restriction, and mounted it right out of the sump. After having to drain my tank to open the system, I said this isn't going to fly, lol
By the way, my pump has been in for 2 years, zero problems
Quick Reply: 1018hp Twin Turbo 57 Buick build thread "The Jackal"
