1200hp engine build advice needed - LS3 or Iron block?
Not everyone is on the internet ....And, to me, at this levels your getting into magnum cranks, grp rods, etc... Where those parts will take 2300who of abuse at which point you need 6 bolt heads and the lsx or dart next block for better crank support.
Its kind of a weird niche of people who use it or need it...But Someone with a slayer crank, tfs heads, and a rod better than a comp star in a 4 bolt block could use these gaskets and max out their combo further than it is today with a little peace of mind...they are that good.
I don't know much about the drag racing rules and different organizations....but a bunch of people go to him for these 6 and 7 second drag classes. He builds LSx single turbo engines for these cars. I stop by his shop all the time to say hello when I'm home from the Middle East. He always has 6-8 LSx builds going on, always had C5R engine builds in progress, ERL and Dart builds going on. And a bunch of regular sleeved badass LSx builds and iron LSX builds going too. It was an LSx candy store........
tvanlant, I would recommend that you consider one of our LS NEXT Aluminum blocks. They are designed from the ground up to be the strongest and most well engineered blocks available.
Consider these features:
http://dartheads.com/dart-product/ls...um-standard-2/
http://dartheads.com/dart-product/ls...um-full-skirt/
• Skirted and non-skirted design option available.
• Priority main oiling system.
• Available in deck heights from 9.240” up to 9.950”.
• STD or raised .388” cam location.
• Cylinder barrels extended .375” at the bottom.
• Extra thick decks ensure reliable head gasket seal.
• Blind head bolt holes don’t go through to water jacket.
• Scalloped water jackets increase flow around cylinders for better cooling.
• Clearance for 4.100” stroke w/ steel rods.
• Splayed outer bolts on middle main bearing caps.
• LS and Gen I style motor mounts.
• Provisions for OE stock roller lifters and cam.
• Uses stock timing covers and stock rear cover.
• All OE bolt holes for starter, water pump, etc.
• Driver or passenger side starter mounts.
• Parts kit sold separately (PN: 32000017).
I just don't understand why people would spend all the time and effort gold plating the GM iron block.. Yeah its cool that a few guys out there have pulled it off but a LSX block is a hell of a lot easier and built better. Just doesn't make sense to me. To each their own I guess.
The LSX block has head gasket issues around 2000hp even with the 6 bolt heads as an fyi...
I think most people build around the unicorn of 1000hp and 160mph traps - That makes for an outrageous street car and a really fast track car. But both of those marks are on ragged edge for an MLS gasket 4 bolt LS motor.
Yep, agree with you that an LSX block is better right off the bat and worth the investment. Unfortunately a lot of people in this game are carefully managing budgets (sounds funny) but it's true.
The LS NEXT Aluminum is $5055.05 Jobber. Add $500 for 1/2" mains. Add $170 for 1/2" head studs. Add $100 for full skirt style block.
If you want a great block, but are tight on budget. I would recommend the LS NEXT SHP block. It is $2330 jobber and does not need all the expensive machine work that the LSX next block needs. We took great care to make this the goto block for guys on a budget.
Whats the difference in the SHP LSNext Block vs the LSNext Iron Block?
I'm interested in the LSNext line of blocks and was planning on eventually going with an LSNext Iron Block but I'm now seeing the LSNext SHP blocks and aside from the skirting I'm not really sure on what the differences are. Is the price diference of the SHP vs Iron LSNext block much different?
The LS NEXT iron is a high nickel iron block that uses a special oil pan for improved windage. The LS NEXT iron block also has a Moroso adapter available to use an OEM style LS oil pan. Because of the alloy, the LS NEXT iron block is ultimately stronger than the SHP. The LS NEXT iron has a jobber price of $2637.18
We rate the SHP up to 1500 HP although we don't really know its limits yet. As you know, that can be influenced by usage/user. We recommend the LS NEXT iron or LS NEXT aluminum above 1500 HP.
The LS NEXT SHP block is a grade 30 iron, fully-skirted block designed to be stronger, better oiling, 6-bolt direct replacement for the factory block. It is $2329.55
#32
#33
You can also Darton sleeve an iron LSX block and it'll still cost less than the aluminum Dart. That would be the ultimate in strength for a block.
#34
Do you think that LS NEXT Aluminum block is stronger and more reliable than an iron LSX block? $5,800 is a lot and still have the week point of sleeves, compared to all iron?
Also, we have a billet aluminum block for the ultimate in strength and repair-ability.
#35
Cam tunnel, main line and lifter bores will all need to be finished. So, the LSX block will cost you a lot more than the LS NEXT to get ready to assemble.
If the extra weight of cast iron is not a problem, then consider our LS NEXT iron block. We made it to be the strongest and best cast iron LS block you can buy. And, as noted above, it is much cheaper than the LSX block becasue it does not need the additional machine work.
#36
#37
ERL Option
OP,
I would love to talk to you about our blocks. Our Superdeck 6-Bolt engines have been proven for many years in mild street applications as well as race dedicated 2,500HP+ cars.
Our block comes in about 150lbs. lighter than an iron block. The length of the sleeves/liners is also to be noted. Our liners are 5.800" which really helps with piston rock at BDC versus shorter liners.
This October we have new pricing coming into effect, because of the volume that we are now doing and since we have re-tooled our machinery to only LS blocks, we are now able to offer an even better price for our blocks.
Because we start with a factory casting you don't need to any aftermarket adapters, everything bolts right back on.
Here is a link to our block options with the new pricing listed, another nice thing about our blocks is that all machine work is included, you get the block ready for assembly! : http://www.erlperformance.com/produc...-for-assembly/
#39
OP,
ie, does it really matter which core you start with ?
As I'm not in the US, outright purchase is the only option.
Also, can you add piston oil squirters to your blocks ?
#40
one of your billet blocks, all-pro's etc.... just one of those uhhhhh that's expensive kinda things.
