Bracing the turbo to the frame.. will this work? (Diagram)
Old 10-11-2016, 10:31 AM
TXjeepTJ's Avatar
Default Bracing the turbo to the frame.. will this work? (Diagram)
I have a 1970 Chevelle.. 6.0L that I am doing a turbo on, which will be located right behind the passenger side headlight. Because of this, I cannot brace the turbo to the motor, and will have to brace it to the frame.
I will be running truck manifolds flipped. Here is a horrible diagram I drew up on how I plan to run piping, etc.
Will I be safe with this setup? Mainly mounting the turbo to the frame and using flex pipes in the locations shown? Or would I still run into problems with major flexing? I am not running solid motor mounts.
Old 10-11-2016, 10:46 AM
MM98's Avatar
As long as you have a flex pipe on each up pipe you should be fine
Old 10-11-2016, 10:51 AM
svslow's Avatar
My set up is exactly like that.
Old 10-11-2016, 10:57 AM
usmc50lx's Avatar
Swap motor mounts...boom problem solved. but the flex pipes will work as well
Old 10-11-2016, 01:44 PM
3 window's Avatar
Here's a small simple bracket I made to support the turbo. Doesn't take much.
Old 10-11-2016, 02:15 PM
wildcamaro's Avatar
I built a similar brace in that location on my 81 camaro
Old 10-18-2016, 09:49 AM
TXjeepTJ's Avatar
I have another question regarding the flex pipe. I bought some G8 exhaust Manifolds for my turbo hotside. They came w/ the cats attached, which have these very flexible couplings attached.
Can I get away with just using these flex couplings at the location they are in?? and not install flex couplings in the spots I originally showed in my diagram.
Quick Reply: Bracing the turbo to the frame.. will this work? (Diagram)
