3rd td time is the charm? 2010 Camaro SS stock bottom Huron 76mm
Went back with new wires... they seem to hold, but I was having some boost drop issues past peak torque. After some research online, it may be tied to the boost controller.
Any who... here are the results:
8psi - 571rwhp/575rwtq
10psi (10psi @pk tq/9psi @ pk power) - 611rwhp/613rwtq
16psi (16psi @pk tq/ 13psi @ pk power) - 703rwhp/762rwtq
IFrom my research, iof it is boost controller related (the boost drop), it would be related to the "wastegate crack psi" I unputed. If so, it seems that the higher psi is a spike, and the psi it settles too is what it should hold flat (meaning, the duty cycle I had for 16psi really is for 13psi, but I saw a spike up to 16psi).
So... that would mean 13psi is good for ~700rwhp, but the torq at 13psi will be lower once I can hold steady boost.
List of mods:
Huron single turbo kit with Precision 7675
3" DP into dual 2.5" Borla ATAK
Stock short block (c hair higher than stock compression)
AI LS3 280cc heads
Vengeance Racing 235/231 .6xx/.6xx 115lsa
ported ls3 intake
NW 102 TB
93 octane - 1000cc injectors, stock fuel rails and lines, zl1pump, adm fpcm
slp underdrive 25%
Alky control dual nozzle kit...4psi turn on
AEM truboost and failsafe
List of mods:
AI LS3 280cc heads
ported ls3 intake
NW 102 TB
slp underdrive 25%
List of mods:
AI LS3 280cc heads
ported ls3 intake
NW 102 TB
slp underdrive 25%
List of mods:
AI LS3 280cc heads
ported ls3 intake
NW 102 TB
slp underdrive 25%
