MS3 Pro W/Co2 for WG
Recently got a MS3Pro and now I'm looking to use Co2 to control my WG. Is anyone using a MS3pro for this and has any advice/experience how it worked? Thanks!
From my understanding it is still in BETA testing. I know of two local guys using it with decent results but it is not perfect...yet. Supposed to be out soon though. I can't wait for it because I too have MS3Pro and bought an onboard air system to do the same thing.
Is there a new BC coming out in in Beta?
I don't use the PRO, but I use the BC on the MS3 and it works just fine. All it's doing is pulsing a boost valve. C02 control is no different than "Standard" BC using manifold pressure.
Set it up just like any other BC method. Use a weak WG spring and run a regulated C02 source to a BC valve, then to the top of the WG. Set the WG up to pulse at the DC that nets you your target boost.
