L33 Silverado ECSB 4wd, Stock 4l60E, S366 Single, 400-450whp
I'm in the process of specifying all the parts for my turbo build. The plan is to use a Trick T4 manifold as the foundation of the kit. I'll use an Ebay intercooler. DIY mild steel piping for the cold and hot side (DC only TIG welder).
I'm just looking to make my truck a little more fun around town. It's main purpose is hauling around mine and my daughters dirt bikes. I really don't tow much at all.
It seems like an BW S366 turbo should be perfect for this application and have great spool characteristics. Any thoughts on this turbo choice? These turbos are easy to find on Ebay for around $600. That seems like a small enough jump from the Chinese turbos to make getting a name brand turbo worth it.
I plan to fab up the whole kit, then have it professionally tuned locally.
Any thoughts on this setup before I pull the trigger and start buying parts???
APPARENTLY you can also tig aluminum with DC positive in a pinch.
if only care about performance you can always just wrap the piping. I dont think heat soak is going to differ much from steal vs aluminum as they are both inside the engine bay= same closed environment temperature and nothing cooling it down.
I guess you could argue that inside temp from the intercooler is lower temperature? but its flowing so fast and only there at a split second that any(if all all) absorption of heat would be negligible that I wouldn't even worry about it.
I did wrap mine because it was right on top of the turbo(but i would have wrapped it even if it was aluminum.)
600whp no issues.
you can dc tig aluminum. look up helium setup for dc tig.
600whp no issues.
600whp no issues.
that leaves you with 3 options.
1. use a bunch of coupler to make the bends.
2. take it to a shop = $$(if you got it then cool)
3. cut and tape it in place and hopefully it doesnt shift when you take it to the shop to get welded.
cost of material isnt the issue here its the cost of tig.
ill take steel pipe that fits correctly and paint it black if you really want that "clean" look. done.
if you got a buddy that can tig aluminum consider yourself lucky. if everybody has that kits woulnt be so expensive.
