240Z LS3, 8 second turbo build.
Mine had the D3 transbrake as well. I sold mine before it was ever run. It sold very quickly though. I think it was around 1 week on here.
The glide is much shorter than the 4L80E. Sadly your carbon fiber driveshaft is not going to work especially since you already have your engine set back in the chassis so that will most likely be an expense you might not recoup since it looks very short from the pictures.
Nothing special, but picked me up a Glide today from the local yard. Will use it for mock up and will price filling it with good parts and casing it later, or see if the budget allows a new unit from someone
Plus, picked up a race cover for my billet s480 today
Also paid for another set of 1000cc injectors. I'll have 2000cc now total fuel running E60
Anyone looking for a stage 3 80e with triple disc converter?
Tearing into this glide, I'm happy with what I see. In may give this a shot rebuilding it myself as my 80e has been working flawless and have another 80e going together for tow rig
Looks like the expensive part is the 1.80 gear setup. I know my combo needs an aftermarket case to run its fullest potential, but I may just do the stock case at first and pull timing on the hit to keep the tq low and roll boost on based on rpm, same with the gear shift
Still looking at all my options though
Your car is very light, even a stock case trans should survive quite awhile. You will just need to run a shield and if you have the extra add a blow proof bell. With all that extra room you made to fit the 4L80 you shouldn't even have to clearance for the shield! Lol.
I have two cases, and we're talking just a bell that uses the pulp bolts
I have my tranny slated for a friends car now, 2000 minus the brake and some hard parts, so I'll sell those here which makes life easier since no big shipping items
Io have close to 2700 to buy glide parts and a converter. Converter will be in the 800 to 1000 range, so I'm working with say 2000 in parts now. I have a 1.80 year setup and a billet roller support. I'll price in an ati case, and hard parts. My shopping cart at summit is filled, just need to sort through it
Looking at a sonnex servo, fti rebulild kit where I'll sneak in 7 frictions, I'll do a turbo input shaft and do the pump mods with the steel drum
I've already talked to my driveshaft guy, the roller tail housing slip yoke is spendy, so going to try to find a bushing tailhousing
My 80e currently has a flex sheild and a blanket, so if I need to that stuff can transfer over
On a side note, I started a billet block that is -10 inlet with four -6 outlets to feed the rails
#32
4303 and regulator are here. Was able to get the 80e out today without messing with the engine Since it's motor plated front and rear I was concerned about the clearance I left during tunnel demo. The 80e just snuck out and have the empty stock Glide case installed. Should be good for driveshafts measurement and tranny mount install (note, i run a rubber flexible mount on the tranny with the engine plates
Very happy with the look of the glide on there and will be able to fab up a pretty deep oil pan and still be above the subframe connectors
#33
You posted above you were looking for a bushing style tail housing? Those stock glides should have come with them. A lot of companies just use stock tail housings on their builds unless you pay extra for the roller upgrade. They just use a TH350 style yoke.
#35
I love making things so I'll give my try at the oil pan. I can be 2.75 inches deep and be about 1/4 above the rails. There a lots of room around the tranny after clearancing for the 80e! It is a little tight for the shift linkage, but nothing bad
Do I need to worry about the strength of the stock tail housing? Any external welding that can be done to beer it up a bit. That would save over 200 bucks in tail and slip yoke costs
I'm set on the ati case and bell, I even see summit is reselling a bell and case too.
#36
#37
Been tinkering on the car. Moved the radiator forward about 6 inches which made way for the better fan shroud this year. Cold side is all redone with the new race cover
Next up is tranny cooler mounting
#38
Was doing some googling and rumor had it that gm hubs use the same bearings as my S30 chassis and literally bolt onto the car. That led me to Wilwood's web site and after some dimension i found that a G body car runs the offset I needed
Ordered one up from summit, and literally it just about fell into place. The gm bearings are closer together than my 240's so the outer bearing would bind on the spindle taper before seating all the way on the races. Was able to shim with .030 worth of pinion shim and that was enough for bearing preload and align my rotor/caliper setup
I'm excited about the alum front hub, there 3 to 4lbs lighter than my cast units each and the rolling weight is notably lighter. So less unsprung weight, has to be a good thing which will allow me to put weight on the nose if I need
#40
Converter and input shaft are in the mail. Rest of the parts will get ordered next week. Stock case is installed and the tranny crossmember is modified and bolted back in
I decided to go with the bearing ATI case
All in all it's coming right along
About midway through the wire cleanup right now
