Looking for some installed pictures on Huron Speed V2 a/c turbo kit
Hi,
I bought a huron speed v2 a/c kit but looking for some pictures and information/tips on installing this kit.
Maybe somethings I may need to do before installing it....
And on my build.
My goal is 800ish
I have 2002 6.0 with ls3 top end for it but not sure if I should forged it....
Thanks for the advice ,appreciate your suggestion...
And on my build.
My goal is 800ish
Hi,
And on my build.
My goal is 800ish
And on my build.
My goal is 800ish
Fitment is great make sure you have the turbo kmember though. Only think that gave a little fight was the drivers bank header. Take off the factory heat shield from the motor mount and push the power steering lines out of your way. Its a tight fit but with those things done you can wiggle the header in. I also removed the alternator which gave plenty of room to get the header bolted in and then I reinstalled the alternator.
Its pretty straight forward so just ask questions if you get hung up
