'96 lsx Camaro 370/s480 Build
#41
2 things:
1. I squeezed my drivers side collector down next to the alternator about as close as you did...are you using factory F-Body alternator? I want to upgrade and want to use a truck one, but I hear its physically larger...what are you running? I am also concerned with killing it with heat...even though its heat wrapped there...do you have any concerns with this as well?
2. Have you ran an aluminum downpipe before? I wanted to do this but just couldnt trust the high heat here with aluminum. It would be above or close to annealing temp and I could see it deforming over time maybe...Look forward to your feedback on this. thanks
#42
This is the ls1 alternator. The ceramic coating keeps the temps down very well. I am not worried about the alternator heating up from the hotpipes.
Yes ran aluminum down pipe on multiple setups. It will be fine. The downpipe really doesn't get that hot.
2 things:
#48
First outing broke into the 9s
Update***
finally made it to the track with this build. Ran a 9.9 on spring pressure second pass off the trailor then a 9.7 on 17.9 psi (still need to work on the 60ft) then upped the boost more to try and hit low 9s and wheelied and came down and cracked the tranny pan. Lot left in it
#53
New update. Car ran 9.35@146@18.2 psi. No change in boost just improved my driving skills and tightened up the front shocks and installed travel limiters. Hopefully hit 8s in a few weeks
#55
Amazing build.
#59
Mickey Thompson 275 et pros. It's a holley mid ram. I'm running cathedral port heads so the high ram is too tall and hits the windshield. Rectangle port heads/hi ram are about an inch lower
