Boosted Dorman truck intake?
Well yesterday I spend about an hour and I ported all 8 runners and shaved off a few more of the tabs on the top of the intake. My aluminum cutting bits and electric high speed grinder literally took 5 min to cut each port. Love love love porting this nyon stuff lol. The tabs on the top of the intake took longer with a dremel but I'm still contemplating keeping the other tabs that hold the PCV hookup. I know it looks not as great but I need a port for the PCV and the one on the side points straight up. So if I use that I would have to find a 90 or 180 rubber or silicone fitting to connect to.
I ported and removed all the wedges in each intake tract and opened the area right below the injector bung a smidge. Port width is similar to stock but they don't have the injector side blocked off. This leaves a cavity behind it and thus would produce trubulance. The dorman is fully open and the port is taller due to this.
http://cimg6.ibsrv.net/gimg/ls1tech....4378095099.jpg
http://cimg1.ibsrv.net/gimg/ls1tech....915abb7127.jpg
http://cimg3.ibsrv.net/gimg/ls1tech....3db440dac3.jpg
https://cimg5.ibsrv.net/gimg/ls1tech...b07049dc98.jpg
http://cimg6.ibsrv.net/gimg/ls1tech....682b711a28.jpg
http://cimg7.ibsrv.net/gimg/ls1tech....f97af80c1f.jpg
yup but it still looks like crap compared to the dorman. For me a 4bolt TB would have been an added cost and bad. I don't need bigger than the stock 75mm TB.... that's what boost is for. People have made over 800rwhp on stock TBs and intakes. Even if I don't gain any power over the stocker the looks alone are worth it. I highly doubt I'll loose any power tho judging by what I've seen while looking at the intake. Large plenum, larger runners... straighter shot to the head should make and support more HP.
Either way the intake is done and ported. I have removed all the tabs and now I'm yanking the motor apart to start swapping parts.
New PCV port hookup.
Andrew
sure but that is not what this thread is about. The dorman is a 3 bolt TB for us stock style cable TBs and it looks better and can handle boost. I wasn't saying it's the only intake or the best. But word is that it should flow equal if not better than the TBSS intake and look better doing so. But either way your right TBSS is top dog of OE intakes and if you got a 4 bolt TB.... congrats everyone already knows that. But point me in a direction of a 3 bolt plastic style intake on the cheap that looks good?
#32
Just last night during my cam swap I got some oil on the new wrinkly painted valley cover and It wiped up easily the wrinkle shreds the paper towel alittle lol.
#34
Nope. That was an LS6 dorman intake that blew up at 15psi. They are a different design between the truck and LS6/LS2 versions. The trucks are literally Bolted together where as the LS6/LS2 are Sonic welded only.
Also since I'm only running 12psi (and it should be alittle less with the new custom cam/ported heads) so I'm not worried as I'm lower than what that guy blew it up.
I haven't seen anything on the truck intakes blowing up. In fact there is very little info on them out there. Only one guy took his apart and supposedly it was a prototype and he had to richen up his tune alot due the extra air but he also had a host of leaks (prob from him not having the right seals to replace where the peices come together) and I think he just used RTV or something. So I dont take that as a valid issue as he took the intake apart.
#35
Restricted User
The one I'm talking about wasn't a blatant failure like the LS6 intake. It didn't split in half, but ended up leaking from half a dozen spots and had a large crack near the TB.
I can't find anything on it now. I could be completely wrong but I passed on one of these from craigslist that was $80 after I seen the post.
#37
This is all i could find and it was the LS6 version and blew up at 15lbs under load.
#39
yea me too lol... IF it doesnt then I learned but it wasn't a waste of too much money. If I blow it up in 6 months I'll get summit to accept the return and refund as they are pretty good with that. I won't be getting back to back info. The motor is getting a full upgrade, custom blower cam, ported replacement stock heads and now the intake, ported TB etc. I dont do dyno sessions but I know I'm going to get a minimum of 80hp from the cam upgrade according to cam motion. so any seat of the pants power increase is going to be from those other supporting mods.
#40
But there are key design changes between the LS6 version above and the truck. Truck is bolted together even at the front and back over the valley area where the LS6 is just sonic welded. You can see in these pics kinda that the front and back of the truck intake there are multiple bolts that hold it together.
2 bolts in the front and 5 in the back I think.
