Turbo feed line and fitting
Guys I need help! Where do I get long enough to feed line to get from my block off plate to the turbo far front passenger side. Also wat fitting and plate do I use to bolt the line to the turbo?
much appreciated!
much appreciated!
Restricted User
Without knowing what turbo you have, we can't recommend you a fitting.
Get some push-lock hose with a couple of end fittings. Cut to length. Ebay has some cheap nylon braided hose as well.
and I bought and ebay kit the the feed line is too short and in my area no one has -4 AN
Then what do they have ?
In days of old...people used copper, steel etc hardline to feed oil to the turbos. If you cannot purchase a generic length of -4 teflon, then just use whatever you can get locally to route oil from the engine to the turbo.
Hydraulic oil line would be another option if there is anywhere local that can repair/replace hydraulic lines.
Just scroll down for the lengths and end types you need....
Premade -3an.....
https://www.anplumbing.com/extras/premade-3-hose.html
Premade -4an....
https://www.anplumbing.com/extras/premade-4-hose.html
Premade -3an.....
Premade -4an....
Premade -3an.....
Premade -4an....
Premade -3an.....
Premade -4an....
