Log Manifold question.
Old 01-21-2017, 06:17 AM
olegreen94's Avatar
Default Log Manifold question.
I see a lot of these log manifold setups that look really clean and seems like the simplest way to do the hot side if the chassis configuration allows for it...
My concern is all that weight hanging off a aluminum cylinder head. Do most people brace the turbo to the block? Is a log manifold setup ok for a T6 borg turbo considering its size and weight. Also has anyone had issues with one cracking yet, may it be homemade or one from kb racing/trick manifold?
Old 01-21-2017, 06:31 AM
alocker's Avatar
If you use one of the logs mentioned you won't have issues. Myself and plenty others have been running Borg's on them no problem.
Old 01-21-2017, 10:41 AM
drecpt83's Avatar
I'm running a kb racing log manifold in my g body. Excellent craftmanship, and it's made very sturdy
Old 01-21-2017, 03:17 PM
brandon6.0's Avatar
yea KBracing makes some nice logs. I wanna say there sch40 mild steel. plenty strong!
Old 01-21-2017, 03:19 PM
brandon6.0's Avatar
The trick logs are now cast stainless. KBracings are mild steel. Both will serve the same purpose. A lot of truck guys use both with big t6 turbos without any bracing. No issues.
Old 01-21-2017, 09:09 PM
olegreen94's Avatar
Thanks guys. Just seems like a lot of weight hanging on the manifold bolts into a aluminum head. But if it works great.
Old 01-21-2017, 09:26 PM
brandon6.0's Avatar
u can install some studs to help with mounting and alignment to the head.
Old 01-22-2017, 07:46 AM
forcd ind's Avatar
I thought the same thing orig., I have the KB manifold going on 2 years now,
no problem-guys have done Drag Week using them
The bolt holes on the head are not in a perfect line, a little offset, so that gives a little more stable bolt system
Old 01-22-2017, 12:54 PM
Project GatTagO's Avatar
Received 1,384 Likes on 873 Posts
Holley is coming out with a cast iron log soon.
Andrew
Old 01-22-2017, 12:55 PM
truckdoug's Avatar
there's six 8x1.25 bolts with better than double the major diameter thread engagement. thats a metric ****-ton of fastening power.
a good practice is to egg the holes in plane with the length of the log, as it tend to grow with heat (and it'll see a lot in a turbo app)
studs are nice. my personal pref is to stay away from stainless fasteners for exhaust. it's more trouble than it's worth, especially going into aluminum. unless it's all you got, then find a badass hi temp anti-galling compound and dont rattle gun them in
Old 01-22-2017, 12:56 PM
truckdoug's Avatar
Andrew
how much do you get paid everytime you mention the holley manifold?
Old 01-22-2017, 05:56 PM
olegreen94's Avatar
All good info thanks again. The log manifold setup will make it clean and simple in a S10 platform that we are working with.
Old 01-22-2017, 05:59 PM
kainedogg's Avatar
Lol, at that.
Old 01-22-2017, 06:37 PM
kbracing96's Avatar
Yeah, they are plenty strong to hang even the heavest of BW or Garrett turbos on them. Been building them for about 10 years, hundreds of them. Sced40 steel pipe. Only ever had one guy pretty much destroy one, cracked and warped... He thought he could make a diesel pulling type truck out of his gas rig and pull 10K+ loads as hard as it would run through mountains! lol
Old 01-22-2017, 09:02 PM
Zero...I am just excited about it because for the first time I can put together a simple turbo system without doing a bunch of custom ****.
Andrew
Old 01-22-2017, 10:46 PM
truckdoug's Avatar
but but but doing custom **** is the fun part!!!!!
Old 01-23-2017, 02:01 AM
chuntington101's Avatar
Ppfftttt cast incconel is were it's at!
(Inconnel holds heat much better than stainless and can be made thinner as it maintains its strength at higher temps)
Quick Reply: Log Manifold question.
