*The ulitmate street/strip build* F1C procharged trans am ws6 ~pic heavy~
Old 01-21-2017, 12:27 PM
josh4ku's Avatar
Default *The ulitmate street/strip build* F1C procharged trans am ws6 ~pic heavy~
Now that the rest of my build will be happening quickly the next 30 days, I thought it would be nice for followers to see a new thread since my previous build thread was old, and details changed throughout. So now that everything is purchased & set in stone, I'm going to recap everything that has happened so far along with details here!
This is a 2002 trans am ws6 with a F1C procharged 376 will FLEX FUEL! This will be 90% street car, my goal was to build a car that can be fueled up anywhere, retain all of the factory accessories, great sound system, and avoid parts that cause annoying clunks & added interior noise. No intentions of installing a roll cage since its primary street driven. I was very careful choosing the parts for this build with street driving in mind, although since it won't be a daily driver it will have some cam lope and obviously won't be the quietest car with the true duals HP goals are 700-800 range! Im not going for 1000 hp just because it sounds cool, I want enough hp to scare most people, and still hook decently on the street without running 15" wheels with fat tires.
SEE BUILD DETAILS BELOW!
EVERYTHING RELATED TO THE ENGINE!
  • NEW FAST LSXR 102MM INTAKE W/ HOLLEY 105MM W/ LOW RPM TAPER THROTTLE BODY
  • NASTY PERFORMANCE FUEL RAILS
  • FID 1100CC INJECTORS
  • 450LPH DOUBLE PUMPER KIT W/ SQUASH PERFORMANCE KEVLAR BRAIDED LINE KIT
  • BTR TFS 235CC CYLINDER HEADS MILLED TO 64CC, HAND BLENDED BY BTR
  • BTR VALVE SPRINGS
  • ARP HEAD STUDS
  • LS9 HEAD GASKETS
  • STOCK ROCKERS WITH BRASS TRUNION UPGRADE
  • TEXAS SPEED 7.425 PUSH RODS
  • JOHNSON 2110 DROP IN LIFTERS
  • 227/244 115+5 BTR blower cam
  • MELLING HIGH VOLUME OIL PUMP
  • ATI 10% UNDER DRIVEN DAMPENER
  • Blue printed New LS3 aluminum block Gen IV
  • King racing chamfered main bearings
  • King racing narrowed rod bearings
  • GMPP cam bearing set
  • Forged Diamond -11CC 10:1 COMPRESSION RATIO
  • K1 forged crankshaft with reluctor 3.622"
  • K1 Technologies 4340 H-beam connecting rods
  • MIGHTY MOUSE FULL PCV CATCH CAN W/-10 AN INLET
  • KOOKS 2" COATED HEADERS
  • KOOKS TRUE DUALS EXHAUST W/ MAGNAFLOW 12219 OVAL MUFFLERS
  • CUSTOM FABRICATED STAND UP RADIATOR. GRIFFIN RADIATOR & STAND UP A/C COMPRESSOR WITH CUSTOM A/C LINES!
  • SPAL RADIATOR FANS W/ CUSTOM RADIATOR SHROUD
  • TICK PERFORMANCE BATTERY RELOCATION
POWER ADDER:
  • STEVE MORRIS MODIFIED F1C PROCHARGER W/ ASTER BRACKET WITH A 4.00" PROCHARGER PULLEY & 7.65 CRANK PULLEY.
  • BIG RED RACE VALVE
  • 4.5" bell intercooler/bracket and cold side from Huron speed
TRANSMISSION:
  • NORTH TEXAS CONVERTER STAGE 3 4L80E W/ RATTLESNAKE TRANSBRAKE RATED TO 1350FWHP
  • FTI TRIPLE DISK CONVERTER FULL LOCK UP CAPABLE
  • STOCK SHIFTER W/ CAMARO ****
  • BMR 4L80E CONVERSION CROSSMEMBER
REAR END:
STRANGE S60 3.73 GEARS
FRONT SUSPENSION:
  • KYB ADJUSTABLE SHOCKS W/ STOCK SPRINGS
  • NEW UPPER & LOWER A ARMS
  • NEW BUSHINGS
  • NEW BALL JOINTS
  • NEW INNER TIE ROD
  • NEW OUTER TIE RODS
  • BMR TURBO K MEMBER
REAR SUSPENSION:
  • UMI LOWER CONTROL ARMS
  • BMR LONG TORQUE ARM (TRANSMISSION CROSSMEMBER MOUNTED)
  • PANHARD BAR RELOCATION KIT
MISC:
CARBON FIBER HYDRODIPPED - INTAKE, BRAKE RESERVOIR, PROCHARGER COVER, TRUCK COILS, AND SOME MISC INTERIOR PIECES.
POWDER COATED - VALVE COVERS, VALLEY COVER, TIMING COVER, COIL BRACKETS, CHARGE PIPE, A/C COMPRESSOR BRACKET, ALTERNATOR BRACKET.
GAUGES/INTERIOR :
BRAKES:
  • NEW FRONT & REAR ROTORS
  • HURST LINE LOCK KIT W/ CUSTOM BRAKE LINES
  • WILWOOD PROPORTIONAL VALVE ABS DELETE W CUSTOM BRAKE LINES
  • NEW FRONT AND REAR BRAKE LINES
HERE IS PICTURES OF WHAT HAS HAPPENED SO FAR!
http://s1036.photobucket.com/user/jo...%20build/story
Old 01-23-2017, 03:32 PM
josh4ku's Avatar
Made some progress, but then found an issue already. Bmr is sending a new k member. So won't have much progress until later this week.
Did I'd get the line lock and proportional valve mounted nicely with new brake lines routed.
F
Old 01-23-2017, 10:59 PM
ta02zx10r's Avatar
If you're planning on painting the engine bay..... Now is the time to do it. Take your time and clean everything up. You'll have a much more fulfilling build and end product if you do.
Old 01-23-2017, 11:03 PM
josh4ku's Avatar
already done!
Old 01-24-2017, 12:20 AM
4Barrel's Avatar
Subscribing! Very nice. High five!
Old 01-24-2017, 10:22 AM
josh4ku's Avatar
Thanks!
Old 01-24-2017, 11:12 AM
sweet99ss's Avatar
What a dick no high five back to the guy lol. Seriously can you tell me more about the line lock? Looks nice what is the function?
Old 01-24-2017, 05:06 PM
blindboyth's Avatar
Very similar to my 383 f1c build I am wrapping up. I will be following yours.
Old 01-24-2017, 09:13 PM
ta02zx10r's Avatar
Awesome buddy! I'm glad to see that. Its sad to see builds with tons of money invested into a dirty car. Makes things seem like an after thought. Wouldn't everyone agree?
Old 01-24-2017, 09:14 PM
ta02zx10r's Avatar
Very nice build very nice
Old 01-24-2017, 09:16 PM
ta02zx10r's Avatar
Btw I see your from Kansas. I moved to Wyoming but I'm from west Kansas. Did a little exploratory drilling around Morland several years back.
Old 01-25-2017, 07:42 PM
josh4ku's Avatar
100% my last build i didn't paint the engine bay, it was navy blue. Looks really bad!
Old 01-25-2017, 07:43 PM
josh4ku's Avatar
Nice! Yup I am 15 minute drive from morland, not much here lol
Old 01-25-2017, 07:49 PM
josh4ku's Avatar
Alright brake lines are finished. T the rear brake lines together, then ran new line to the proportional valve then to the brake booster.
Also decided to run new line on the member to a T then to the line lock and on to the brake booster. It ended up looking really nice, no more brake lines all over the place, no big bulky ABS block anymore. Everything is tucked nicely towards the back!
Old 01-26-2017, 10:11 AM
josh4ku's Avatar
Working on mounting shifter today! Decided to go with the stock shifter with a camaro ****.
Old 01-26-2017, 06:02 PM
josh4ku's Avatar
Default Bmr k member issues!
I am officially ticked off at BMR SUSPESNION. My first K member from them didn't fit right. On the drivers side ones I tightened the middle fastening bolt there was still a big gap between the body and the front and rear fastening points. Passenger side fit perfect. I called them and they were nice and sent another k member. This was is the same or maybe a little worse. As you can see from the measurements to the ground which I know isn't exact but this shop was built about a year ago. I know its dang close! Waiting for tomorrow to see what they say when they open.
Old 01-26-2017, 06:07 PM
josh4ku's Avatar
Made some good progress on the shifter today. Put a thing piece of metal in to cover the 6 speed hole. Covered it with sound deadener showdown deadener.
Old 01-26-2017, 06:19 PM
josh4ku's Avatar
magnaflow oval mufflers showed up today, Im replacing the kooks mufflers in the true dual system with these. Another ls1tech member did this and it quieted the system down quite a bit and took care of the rasp. Excited to get this thing going!
Old 01-27-2017, 08:45 AM
ramairetransam's Avatar
what did bmr say about the k member. Time for a umi
Old 01-27-2017, 05:16 PM
Firehawk441's Avatar
Looks good.
Best of luck with it
Quick Reply: *The ulitmate street/strip build* F1C procharged trans am ws6 ~pic heavy~
