Advice on where to put some money on current setup
Basics: Ls6
383 forged crank/rods/pistons
-30cc pistons. (cant remember exact -cc but about that.
Stock LS6 heads
Cr 8:8
Hardened push rods
Yellow beehive springs
Ls6 TB/Intake,
Twin GARRETT T31/T04E 57 trim .82 a/r
Currently 11psi boost, 92 octane.
Aeromotive 1000 fuel pump, -10 lines, larger rails, 80cc injectors
Will only run 92 octane. Not looking to replace intake manifold due to custom paint. In a 2000lb sand car
Have had fun and want a bit more. Not sure what direction to go. Advice?
Stock LS6 heads
Cr 8:8
Hardened push rods
Ls6 TB/Intake,
Milk?
Filtration is just fine.
Easy to add boost and tune. Was wondering on the cam. Is the ls6 cam adequate? I read it takes boost descent but a turbo cam that may be better for the added cubes.
Boost is much easier to adjust, and compensate for (water injection and so forth).
Whole Milk is a source of protein, carbs, AND fat, in somewhat equivalent ratios, which makes it unique (I don't know of many 'foods' like that off the top of my head but if you search you might find some) The short answer is that, body builders and power lifter types on a 'bulk' need all 3 macronutrients in a hurry, and milk is a quick way to get all 3, and it goes down fast. Mix it with whey protein and you have yourself a liquid steak and fries meal, sort of.
Basics: Ls6
Stock LS6 heads
Cr 8:8
Hardened push rods
Ls6 TB/Intake,
Stock LS6 heads
Cr 8:8
Hardened push rods
Ls6 TB/Intake,
Nor have you indicated that performance is lacking, or where it may be lacking etc.
Or indeed what budget you are working with
You've asked where to put money.....but not given any indication of whether that is for performance gains, for shiny bits...or whether you just want to spend more money on fuel and enjoying it
Built the motor 8 years ago and Spent money on Forging the ls6, for the cost it seemed the heads/intake/cam on the ls6 were descent for hp. And at the time fit my budget.
In the sand you can use all the hp all the time, and you get use to the power. I use to smile more often, so I would like to bump up the hp and get the fun factor back. If I can do it safely by going from 11psi to 15 via correct tune, (which it currently is a safe tune)or add water to be safe it may be an option. I'd guess 4psi of boost is a good 70 hp+-. Or if advised that a turbo cam can get me 70 hp+- at current boost levels that may be an easy option and easier on the motor. The also gives me the ability to add more boost down the line. Just getting info from people and their preferences/thoughts so I can better aim my research. So far seems just turn up the boost. As for budget, I'll spend what is needed to gain a noticeable difference. Not looking for +200hp
Not wanting shiny bits.
Really on the cheap...install a good cam and up the boost a little. Inexpensive and that should easily see 100+hp gain, perhaps more.
A cam should help power everywhere and spool faster too as long as you choose correctly.
Of course the above assumes the turbos are also happy with the additional airflow, but they probably should be.
Restricted User
Install water meth kit and turn it up to 20-25lbs. No reason to touch the engine if the turbo's aren't' tapped.
If the turbos are tapped, look to larger turbos before touching a happy engine IMO. What are the compressor major/minor specs on the compressor/exhaust wheels?
Also watch your rail pressures with that fuel pump. The A1000 is great for low pressures. But a typical turbo pressures they flow diddly. Single AEM 380 inline will out flow an A1000 easy at 65+psi.
