School Me On Meth Install
#41
That's how I believe it to be true. It hinders the other molecules collisions, because it is in the way, so the hydrocarbon, and oxygen molecules can't get to one another to react so quickly. The nitrogen present in the air also does this, as well as the carbon dioxide present after some of the mixture has already started to combust, but we're getting into a whole 'nother story there too.
#43
What caught my eye was the claim that 2/3 of the energy is released in the second stage of combustion where water is required to convert CO to CO2. It doesn't say what role the water molecules play. I'm guessing the water isn't being broken down and contributing any of it's O atoms to the creation of the CO2 molecule. Or does it? Do you happen to know?
Here is what I think it fails to help people understand:
Normally in an internal combustion engine the limiting factor is air, not fuel. So the article looked at it from a fuel stand point and having too much of it. Think of it the other way around, you only have so much air and want to consume as much of it as possible. That is why being richer than stoic actually makes more power than stoic. If you looked at it purely from the point of view of wanting to have the exact correct amount of fuel to get all of the carbon available in it, through the first and second stage, the max power mixture would be 14.7ish. That way you wouldn't be wasting oxygen on the first step, that could be used in the second step if you had just the correct amount of fuel. But we know stoic is not best power mixture. Unless you go to the rich side you can not consume all the air with fuel.
The second thing they fail to mention is that a significant portion of the energy comes from forming the water, not just the carbon monoxide, and carbon dioxide. They fail to mention this portion in their discussion. I'm sitting at the bar in a Texas Roadhouse swilling a Bud light right now, and don't have access, or care to look at any thermodynamic tables right now, but IIRC the formation of the water creates more of the energy, than the formation of the CO2. I could be wrong on this, but I know it is a significant portion. Thus the interest in using hydrogen for fuel, in fuel cells.
And the function of the water in the conversion of CO to CO2 it is just a catalyst, it can happen at high temperature without water present as long as there is free oxygen present. This however would be a much slower reaction, and there is always some water present during combustion to promote this, so it is kind of a moot point. It doesn't take much water to catalyze this reaction, just the moisture normally found in the air would be enough.
I hope this helps more, I kind of feel like we hijacked this thread talking about combustion, more than we did methanol injection. I actually did my thesis on this type of stuff working with a professor that was jointly employed by the university and Shell, back in '91 and '92. Believe it or not we were looking at adding ethanol to gasoline back then, and all its effects on combustion, engines and the environmental impact. In 2006 that became the reality.
#45
You'll still get both benefits.
The concern of the proximity and placement of the nozzle to the BOV is when injecting pure methanol or any concentration with greater than 50% methanol. At less than 50%, the mixture is not flammable in open air.
Obviously, you don't want to have a fire hazard every time the BOV vents.
Not to say that if you did inject pure meth, that it would or wouldn't be "rich" enough to actually ignite if it blew out the BOV (that's another conversation).
It's just a safety precaution.
#46
Actually the Tuning School is doing a video series on meth and water injection on their YouTube channel right now. They did the first phase using just distilled water. They got like a 3 hp and 14 lbs ft torque boost from using water alone, basically the cooling effect of the water. I believe they are going to test the 50/50 next. Previously they tested several fuels like MS109, C16, and ethanol blends. They only tested 40% ethanol though because they are using a Gen 5 engine with direct injection, and it doesn't have enough injector to go any higher. I'm waiting to see the results of the 50/50 and I hope they test 100% methanol.
#48
Well that is after the iat sensor for sure. That's not a bad idea IMO. That way your not going to get it soaked. I think as long as you tune the car with it there you will be fine. If you were to move it later to back before the iat sensor you should retune it. You will compensate for the additional fueling and the temperature drop from the injected solution through your VE and boost enrichment table so that your wide band reading reflects the fueling your hoping to achieve. Basically you will be pulling a little fuel to compensate for whatever fueling the solution contributes. Or adding less additional fuel under boost, compared to what you would be adding without this contribution, however you want to see it.
#49
hey so i'm getting all my ducks in row to dyno soon. first time meth user (lol)
will likely spray 70/30 mix
my plan is to not just rely on sensor data but pull plugs and see what the engine like the old fashioned way. i'll bring a couple sets of tr6's
here's the question of the day....what does water/meth do as far as reading your plugs...same process?
#50
#51
IMHO being on OEM pistons, I'd go for cooling rather than octane. Seems even some pump gas guys go a little rich in order to use the additional fuel for cooling purposes on the SBEs. Again, these are just things I've come across discussing this topic with some other people.
#52
In your case you will have a similar thing happening, a change in temperature of the intake charge after the IAT. So as long as you are spraying a consistent mixture ratio, like 50/50 or 70/30 or such, and a consistent amount, at a given boost level, your tuning will take care of this IAT change that happens after the IAT sensor, just like in the example I gave above on the factory motor. You will want to tune your VE table while spraying the meth/water or 100% meth, whatever you chose to do. If you decide to change pump pressure, mixture ratio or nozzle sizes you should adjust your tune afterwards. If you spray more meth you will need to reduce fueling, and can increase timing a little, if you spray less meth you will need to add more fuel, and pull a little timing.
I'm confident you can tune around injecting it at the throttle body.
#53
Restricted User
You can spray after the IAT and adjust your tune so that its where it needs to be when meth is spraying. I personally avoid this method. There will be no adjustments made and no fail safes if the meth doesn't work.
Spray before the IAT and adjust your tune so that its where it needs to be when meth is spraying. Don't worry about how much it adjusts fuel or anything else. Just spray, and check the tune. Adjust the VE table so your AFR is where it should be for a fully working system. Don't pay any attention to what % of that adjustment is IAT, etc. Its irrelevant. Use the IAT as a fail safe. Your IATs will be very low with meth on 70-90* in most cases. If your bottle runs out or the pump fails, they will be much higher than normal. Have it pull timing if IATs are above 120-130. Its a win/win.
You're overthinking the throttle body portion as well. People are their own worst enemy. Worst case, an ounce stays in your intercooler piping and evaporates off in the next few seconds.
#54
Turbo Addict
This thread is great, and I appreciate all of the knowledge here!
Just a quick question, if spraying before the IAT and the meth/water fails, will the sensor react fast enough to save my engine? I am running MS3 Goldbox and a typhoon thread in sensor.
I have always run my injection after my IAT for various (unfounded) reasons, but would like to try before this time around.
Thanks again
Thanks again
#55
Restricted User
Your engine isn't going to magically blow the instant meth fails. You'll have a cushion as long as you weren't on the ragged edge even with meth.
The IAT should be able to climb from 90 to 120 without meth in ~1 second, maybe less depending on how hot IATs really are.
#58
Overthinking it. Way too much.
#59
Hey 69...How the hell are you. Long time. Seems like some old chevelle.com buddies are chiming in. Yes im in closed loop. Hey guys..this is the guy who got me running since I dont know a MAF to a knock sensor is. I think 69 chvl is a great person for helping me out
