Head Gaskets for #317 heads with stock bore?
Old 07-22-2004, 03:42 PM
1point3liter's Avatar
Default Head Gaskets for #317 heads with stock bore?
I have a set of #317 casting 6 liter aluminum heads and will be running either a 3.902 or 3.905 bore. Boosted obviously..
Some people seem to like the layed 4.040 bore GM gaskets
Others say go with cometics.
I'd prefer the thickness to be around .055 - .060
What headgaskets have you guys had luck with on similar setups?
Old 07-22-2004, 03:57 PM
MECHAM's Avatar
cometic 3.910 bore
Old 07-22-2004, 04:11 PM
Will they interfere with combustion chamber size of the 6 liter heads?
Anyone know the compressed thickness?
Old 07-22-2004, 05:55 PM
99Fbody99's Avatar
GM MLS (Multi Layer Steel) gaskets by far.. and there cheap, less that $30 a pair..Even Harlan runs them still
Dave
Old 07-22-2004, 05:58 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I am:
6.0 heads
6.0 MLS head gaskets
3.905 bore LS6 block
Old 07-22-2004, 06:04 PM
I am:
6.0 heads
I looked back and found someone claiming they were 1.33mm compressed thickness. That converts to .052
Can anyone confirm this?
Part numbers?
TIA.
Old 07-22-2004, 08:43 PM
Speedfab's Avatar
Get off internet, weld heads to block. That will make your thickness somewhere around .000
Old 07-22-2004, 08:53 PM
MYTURBOT/A's Avatar
You have to use the 6.0 bore gasket or they will leak. the compressed thickness according to GM is .055 on the stock 01 up MLS gasket.
Old 07-22-2004, 10:13 PM
MelloYellow's Avatar
Have had nothing but problems with Cometic Gaskets lately. I wouldn't touch them with a 10 ft pole. Am switching to GM MLS now.
I forget the 5.7L bore size. I've heard different bores quoted.
6.0L MLS bore above per PSJ I believe.
Old 07-23-2004, 06:09 AM
smokinHawk's Avatar
must use a 4" bore gasket with the 6.0 heads unless you want them to leak.
i had trouble with my first set of cometics, but this one i have on now is doing alright.
If you dont need a specific thickness/GM thickness would work for you , get them
if you need a specific thickness use the cometics.
Old 07-23-2004, 07:33 AM
"oooooh we can fix that"
Old 07-23-2004, 07:38 AM
Thanks guys,
My compression ratio will work out to 8.5:1 with the .054 compressed height 6.0MLS gaskets so I'll stick with them.
This is off topic with my orginal question, but how many of you are using ARP main studs? At $160 or so dollars are they worth looking into?
Old 07-23-2004, 10:51 AM
LS1Tech Co-Founder
I am using ARP main studs and those fancier H11 head studs made by someone else.
Old 07-23-2004, 12:07 PM
smokinHawk's Avatar
im using them.
i think there good insurance.
Old 07-23-2004, 03:28 PM
Who makes the H11 head studs? What's different about them?
Quick Reply: Head Gaskets for #317 heads with stock bore?
