Anybody Installed an ATI Damper Crank Pin Kit?
I was thinking about installing an ATI Damper Pinning kit. I already have a 8-rib ATI Damper on the car, but was wondering how hard it is to install a pin kit.
Originally Posted by Inspector12
Easy I had to order one when nobody had one to lend and it took me all of about 30min to do and that was me taking my time and double checking everything.
Do I have this *** backwards?
Thank you
TT-TECH Veteran
There are two types one you drill a half moon in each the crank and the dampner. The other is one that you drill a hole in the crank with the pin sticking up into a key slot on the ATI dampner. Sounds like the one you have is from Magna charger kit. That is the type they use on those type of superchargers (halfmoon with a dowel) Hope I explained that well enough for you to understand what I was saying.
