How big are the BIG turbos you guys are running? - LS1TECH
Thread Tools Search this Thread
Old 10-28-2004, 04:33 PM   #1
LS1Tech Co-Founder
Pro Stock John's Avatar
Default How big are the BIG turbos you guys are running?
How big physically are the big turbos folks are running?
And the size of the turbo, like a 88mm, is that the size of the impeller?
Pro Stock John is offline   Reply With Quote
Old 10-28-2004, 04:35 PM   #2
thats how many M&Ms they eat in a minute..
8seclt1 is offline   Reply With Quote
Old 10-28-2004, 04:40 PM   #3
maddboost's Avatar
Quote:
maddboost is offline   Reply With Quote
Old 10-28-2004, 04:42 PM   #4
chronic masturbator
lmao @ 8seclt1
dynedta is offline   Reply With Quote
Old 10-28-2004, 04:46 PM   #5
LS1Tech Co-Founder
Old 10-28-2004, 04:47 PM   #6
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
John, I can get you all the info you need. We deal with DR class cars and some of the cheater turbos. Most are running 88mm inducers, but most of the big turbo guys are running cheater class units, which are 91's and 94's shaved down. Physically....here you go...
Jose
JZ 97 SS 1500 is offline   Reply With Quote
Old 10-28-2004, 04:48 PM   #7
LS1TECH Sponsor
Oh forgot to explain.....from left to right
T91, GT47-88, PTE88, T67
Old 10-28-2004, 04:50 PM   #8
LS1TECH Sponsor
All of a sudden I have a craving for those M&M's. Wonder if I can get those at the local walmart....
Old 10-28-2004, 04:51 PM   #9
maddboost's Avatar
Quote:
An admin posting a NWS what a hipicrit.
Old 10-28-2004, 04:52 PM   #10
LS1Tech Co-Founder
Nice M&M's eh? Me LIKE.
What are the physical dimensions of those turbos? Is that PTE88 have an 88 inducer/wheel???
Old 10-28-2004, 04:53 PM   #11
LS1TECH Sponsor
Yes the PT88 has an 88mm inducer.
I will try to get the physcial dimensions posted up on the site today if I can get them.
Jose
Old 10-28-2004, 05:40 PM   #12
Why is it that Turbos can make much more power( and move more air) than blowers with the same size inducers? For instance my G-trim Vortech has about a 78mm inducer. Max rpm of about 65,000 to maybe 70,000 for my Unit. I suspect the rpm limit for the superchargers is mainly for the gear drive drive system, but which also limits how much flow it's capable of with a given impeller size.
A turbo with that same size inducer seems to be able to flow much more air.
Is this because the turbo can spin a lot faster and thus move more air with the same size inducer?
Steve
S_J_H is offline   Reply With Quote
Old 10-28-2004, 05:44 PM   #13
LS1TECH Sponsor
Yeah.... a turbo can reach over 100,000rpms.
Jose
Old 10-28-2004, 08:20 PM   #14
blackz93's Avatar
i too, have wondered what they are measuring!
blackz93 is offline   Reply With Quote
Old 10-28-2004, 08:21 PM   #15
y2khawk's Avatar
Let's not forget the HP needed to actually spin the blower is alot more than you lose from the backpressure created by the turbo.
y2khawk is offline   Reply With Quote
Old 10-28-2004, 08:25 PM   #16
LS1TECH Sponsor
Good point also Harlan, a blower drags a good bit on the motor. A probably built setup is only going to see a 2:1 backpressure ratio rise, which is not much of a restriction. Now a log style setup can see as high as 4:1 backpressure ratio which robs hp from the turbo setup, but its still going to be as good or better then a blower.
Jose
Old 10-28-2004, 09:21 PM   #17
PRAY HRD's Avatar
i've heard a blower setup making in excess of 1600 hp, can be robbing as much as 300 hp at the flywheel!!!
Dave
PRAY HRD is offline   Reply With Quote
Old 10-28-2004, 09:28 PM   #18
...with cheese.
Armageddon's Avatar
Quote:
Dave
bleh... I guess thats the price you pay for instant power. I don't really get it though. Superchargers are cool, but our motors are pushing enough air to bring lag to a minimum. I personally went turbo and I'm happy with my decision.
Armageddon is offline   Reply With Quote
Old 10-28-2004, 10:23 PM   #19
CHRISPY's Avatar
BWAHAHAHAHA!!!
CHRISPY is offline   Reply With Quote
Old 10-29-2004, 09:27 AM   #20
yeah that may be the single largest reason. MM&FF MAG has a real good tech article this month. They ran a test on 4 different forms of forced induction on a Cobra mod motor. Eaton vs Kenne Bell vs Vortech T-trim vs a pair of 57mm turbos all at the same 11psi. The eaton and kenne Bell made the best off idle low end with the kenne Bell killing the eaton on the top end, the Vortech beat the Kenne Bell on the top end by a good margin and the turbo's made another 70hp more than the T-trim at the same 11psi.
Looks like Turbos simply are the top dawg. The turbos made more power over the Eaton than the Eaton did over N.A. at the same psi!
That is pretty impressive!
Steve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
