The baddest LT1 in the world
Old 04-26-2005, 06:34 AM
smokinHawk's Avatar
Default The baddest LT1 in the world
thought id post this up, at tribute to Big Rick
i thinking off hand but does he have the fastest MPH now
anyways his car is sweet, if he keeps this up i just might do the LT1 swap
Half Filled LT1 Block with splayed billet main caps
Cola 3.875 Crankshaft
Eagle 5.850 H Beam Rods
Custom JE Pistons
AFR 220 Cylinder heads
Solid Roller Camshaft
T&D Shaft Rocker Arms
Dart Carb Style Intake manifold
91.5mm Turbo by Precision
FAST Engine Managment System
JW built Powerglide Transmission
Moser 9" Rear End
Custom Chassis Work by Disturbing the Peace, and Madman Fabrication
8.21 @ 174 mph
http://horsepowerengineering.com/media/Rick.wmv
http://www.highspeedproducts.com/video/Rick.wmv
nws due to language>
http://www.horsepowerengineering.co...cks8.35pass.mpg
Old 04-26-2005, 07:27 AM
Tiago's Avatar
yea, thas a bad mfker.
can't wait to see MO BOOSSSST!
Old 04-26-2005, 07:31 AM
got_hp?'s Avatar
8.21 on half the boost it is designed to run, lmao!
Old 04-26-2005, 07:33 AM
gator's 99TA's Avatar
incredible setup.
Old 04-26-2005, 07:51 AM
NA$TY-TA's Avatar
That new front clip and hood are BAD ***
Love the color... had an LS1 that color.
I cant wait to see what it does when its on the boost it wa sdesigned for
Kyle
Old 04-26-2005, 07:56 AM
BIGBOS's Avatar
That car is RAW
Old 04-26-2005, 08:28 AM
The Big Show's Avatar
Props are definitely well earned. I've seen this car go thru all its transitions and it's definitely a force to be reckoned with. Props to ALL involved cause you definitely can't get to this point on your own.
Old 04-26-2005, 09:50 AM
LS1TECH Sponsor
JZ 97 SS 1500's Avatar
Yeah its a bad car indeed. He backed that run up with an 8.25@172.XX . And all on a production LT1 block.....lol. I believe 1500hp is possible with that motor and setup.
Jose
Old 04-26-2005, 10:05 AM
88SS LS1's Avatar
Jose
Old 04-26-2005, 10:21 AM
smokinHawk's Avatar
forget 1500hp, i wanna see 200mph!!
but anyways his 174mph is amazing
beat harlans MPH, ohio boys and dukes mph.
i love the way that bumper has that hole for the turbo, sweet,
though i dont like the hood perticularly well, just too high IMO, once you get the nose up say good by to seeing the track!
Old 04-26-2005, 10:27 AM
1fastV8's Avatar
I believe i've seen this car in a GM High Tech mag.
Old 04-26-2005, 10:48 AM
LS1TECH Sponsor
They are shooting for 180+mph with the LT1 block. Guess the LT1 block is stronger then we all thought. Funny thing is everyone always has given the LT1 block 1000hp limit, but yet, no one has ever broken a block....so we really don't know. I do know that with 4 bolt splayed billet caps the LT1 block is I believe within 2lbs of a dart block in weight. So its definitely a beefy block.
Old 04-26-2005, 11:47 AM
smokinHawk's Avatar
its amazing how strong the lt1, ls1, lq4 blocks are.
180+mph should be no problem for him if he just cranks up that boost.
Old 04-26-2005, 11:51 AM
Birdie2000's Avatar
Is Rick running a girdle to tie the main caps together? Do you think the fact that the block is half filled is a large reason why it's holding up?
The power that car makes is just insane!
And them are some long *** wheelie bars! lol
Old 04-26-2005, 12:03 PM
LS1TECH Sponsor
No when I spoke to Rick he said he is not using a girdle (due to that fact no one makes one for the LTX block to clear the oil pan), and he is still running the factory caps on the mains...LOL. Its an amazing setup indeed and HPE (Chuck, Rick, Josh and the others) really did their homework on that motor. As for Block filler, well it really only helps the cylinders intergrity, it doesn't keep the bottom end from walking around. Which is even more amazing cause the LT1 with billet caps in the middle 3 and billet caps on the mains with a main cap girdle (which I am working on and to keep the stock pan as well) should make this motor darn near bulletproof. And not to $$$ either.
Old 04-26-2005, 12:07 PM
smokinHawk's Avatar
is he dry or wet sump
i assume wet becasue you said stock oil pan
Old 04-26-2005, 12:12 PM
LS1TECH Sponsor
I'm not sure on his car. The stock pan is us making a main cap girdle, but that is nothing related to HPE and Rick's car.
Jose
Old 04-26-2005, 12:25 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Wet sump
Old 04-26-2005, 12:26 PM
Camaro_Zach's Avatar
god that car is nice. i love the setup. good luck with the car, im sure its got more in it!
Old 04-26-2005, 01:10 PM
Birdie2000's Avatar
Jose, I believe Steve Quinn makes a LT1 main cap girdle. Don't know about using the stock pan, but at that point what's another $250 for an aftermarket pan.
Speaking of stock pans, how do you feel about them for high hp forced-induction applications with an upgraded pump?
Quick Reply: The baddest LT1 in the world
