Forced Ind. Cam
Old 09-09-2005, 01:56 PM
hashtagBMW
Speed Density's Avatar
Default Forced Ind. Cam
is there a good cam for forced induction?
Old 09-09-2005, 02:42 PM
BLK85's Avatar
I want to know too.
But offtopic is yoru time your sig correct?
Old 09-09-2005, 05:24 PM
618HAWK's Avatar
I am going to install a Lingenfelter GT2-3, has been a good F/I for many, not to radical-sleeper.
Old 09-09-2005, 07:48 PM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Originally Posted by BLK85
I want to know too.
LT not LS there big guy...most run somewhere in the 14's
Old 09-09-2005, 08:27 PM
99.9percenter's Avatar
Turbocharger or supercharger?
Old 09-09-2005, 11:00 PM
boostedtransam's Avatar
Get a custom grind cam.
Old 09-10-2005, 02:27 PM
94greencamaro's Avatar
93Camaro and myself are running 14s because we are at 2700 ft in 90 degree weather . If we ran our cars in somewhere like California, i guarentee you we could get around a 13.3.
Old 09-10-2005, 05:59 PM
will62085's Avatar
haha thats funny...my bolt on lt1 (similar mods as this guy) used to run 12's...then spun a rod bearing...lol
Old 09-10-2005, 08:35 PM
ddnspider's Avatar
funny,all the ones i see have 14 sec slips.oh well.
Old 09-10-2005, 08:52 PM
TchargedLS1TA's Avatar
Bolt on LT1 in the 12's?? I need to see one of those!!
Old 09-10-2005, 10:09 PM
Boostaholic's Avatar
Hey this is Chris, I think I talked to you out at Firebird? I have the blue twin turbo camaro.
Old 09-10-2005, 11:03 PM
phoenix's Avatar
ok not to get off topic but what cam is good for boost?
Old 09-11-2005, 05:01 AM
AntiVenom06's Avatar
Try jax racing then.
Old 09-11-2005, 03:13 PM
Reject's Avatar
...i've never heard of a choppy turbo'd motor, all of them always are idlieing very smooth, they usually have about 115 lsa's in them
Old 09-11-2005, 03:15 PM
So a turbo cam sounds like a stock one?
Old 09-11-2005, 03:21 PM
Reject's Avatar
most of the time, thats why i goin turbo, instead of NA motor, want that sleeper sound!!
Old 09-11-2005, 05:00 PM
whynot's Avatar
2700' elevation is not the reason that you are running 14's with bolt ons, I went 13.5 with bolt ons at the same track with the same weather, with stock 3.23 gears, and tuning. all I had was hooker lt headers, custom off road y and flowmaster cat back, k&N fipk, and a set of et streets, my best 60' was 2.05.
I went 13.7 with out the headers. with a 2.08 60'.
and if you were at sea level, you would loose, almost .5 seconds, putting you at mid to upper 13's, the trick is matching componants, and finding the things that are holding you back, it's not always the same for every car.
the two of you need to get ahold of me, and I guarentee we can get both of them into the 13's here. I will be out of town again this week for work, but I should be back Friday night.
Old 09-11-2005, 05:17 PM
whynot's Avatar
Like I was telling you, you need to deside what you want the end results to be, with FI, you can run the stock cam and be in the 12's like I was with both the supercharger and the turbo, on lt1's the cams hold you back some, but so do the heads, so going with an extream cam won't gain you what you might expect with great heads. if you plan on running solid 12's then you can do it with the stock cam, with out a lot of boost, (I was on 4.5 psi on the blower, 6 psi with the turbo) but with my new set up, I should be 12's without boost, and 10's on 15 psi again with 3.23 gears.
Just decide what you want for the end results, fuel economy, et, Saterday night special.
Old 09-12-2005, 12:07 AM
ONealLaw's Avatar
That is correct. A forced induction cam has a wide lobe separation so you don't lose the boost that is being made. 115 LSA is ideal. Also the duration on the intake need to be larger than the exhaust so boost is not bled off. If you ever listen to the big pro stock blower race cars you will hear how smooth they sound but make gobs of power because they retain the boost in the engine. If in doubt call ECS East Coast Superchargers 609-752-0321
Old 09-12-2005, 12:58 AM
longrange4u's Avatar
<---- GT-2 Cam... Sleeper, sweet smooth idle. HUGE Exaust dur.
Quick Reply: Forced Ind. Cam
