Would I see more rwhp - Gear change
Okay I have the sts kit with the stock 10 bolt and 4:10 gears. My 4:10 gears seem to be too much for my turbocharger - It really does not give the turbo anytime to spool. I'm going to a 355 gear would the 355 gears give me more rwhp on the dyno since the turbo can spool.
I'm not sure if it will get you more hp, but I would assume that you curve would look better. The turbo will load better, and give you a flatter curve. I don't know if that's a fact, but it sure does sound good!!
