Best plugs for FI?
Old 01-15-2006, 03:40 PM
DrX
DrX's Avatar
Default Best plugs for FI?
From what I have been reading, it looks like I should ditch the expensive factory double platinum NGKs and replace them with the cheapo V-power TR55 or TR6 plugs. Platinum and iridium are not recommended with FI. Is this correct and how often should the TR55's be replaced? Also, should I alter the OE .060 gap with FI?
http://www.ngk.com/results_app.asp?AAIA=1423886
Old 01-16-2006, 09:36 AM
WILWAXU's Avatar
Lets try this in the FI section
Old 01-16-2006, 10:22 AM
Wolfee's Avatar
Most people seem to run NGK TR6's gapped at or around .032.
Wolfee
Old 01-16-2006, 10:56 AM
Fire67's Avatar
You shouldnt run platinum for sure... Ive been running the TR6ix (iridium) in my LT1 for quite a while with no problems.
The platinums get too hot, start glowing and melting, causing detonation and/or engine damage.
I always run .030 -.035 gap.
The cheapo V-powers also work well, they just dont last as long.
Old 01-16-2006, 10:57 AM
onefastss223's Avatar
TR-6's here...
Old 01-16-2006, 08:51 PM
DrX
DrX's Avatar
Thanks. TR6's at .035 seem to be the consensus here and on performancetrucks.net
Old 01-16-2006, 09:05 PM
V8_DSM_V8again's Avatar
Those should be good.
I run a BR8ES on really high boost engines. Non projected plug
Old 01-16-2006, 10:27 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
5-8 psi? NGK TR6's gapped at .035 would be the ticket. Some might go for .040-.045 to get that little shake out of the idle but you can experiment around.
I run TR8's @ .030 in my current setup.
Old 01-16-2006, 11:18 PM
fastlt1's Avatar
What is the part number for the TR6s for LT1? So the auto parts store can look it up.
Old 01-16-2006, 11:42 PM
http://www.ngk.com/results_cross.asp?pid=TR6&x=43&y=6
You can also run
BR7EF
BR6EF
BR7EFS
Probably not enough boost for that.
http://www.ngk.com/search_char.asp?t...=39&action.y=9
Old 01-17-2006, 12:15 AM
DrX
DrX's Avatar
8-10 psi
Old 01-17-2006, 10:05 AM
LS1Tech Co-Founder
NGK TR6's are still fine.
Old 04-15-2008, 12:52 AM
94m6Z28's Avatar
what about NGK iridums?
Old 04-15-2008, 11:37 AM
MY99TAWS6's Avatar
Ngk iridiums are fine. 6ix should do the trick. Careful when you gap iridiums though.
Old 04-15-2008, 01:23 PM
4SFEDZ's Avatar
im runnin tr6's at 30 they seem fine
Quick Reply: Best plugs for FI?
