GM MLS headgasket p/n (sorry, search is borked)
I found conflicting part numbers for GM MLS headgaskets, need to know which one please so I install the correct ones...
12589226
or
12498544
...or are they the same ?
Need them for my stock bore size Procharged 99 LS1.
Thanks !
Rob (Bad30th)
12589226
or
12498544
Thanks !
Rob (Bad30th)
12589226
or
12498544
Thanks !
Rob (Bad30th)
12589226
or
12498544
Thanks !
Rob (Bad30th)
20-12589226 GM Multi-Layer Steel LS1/LS6 Cylinder Head Gasket
http://thunderracing.com/catalog/?ac...vid=3&pcid=157
bore size doesnt matter......which heads? 12610046 if your running 317s on your motor imo. you dont wana run 5.7 head gaskets on a 6.0 head. the seal ring will be INSIDE the chamber not outside.......if you got 5.7 heads go with SSmokin 01.
Rick
