STS hanging low
Old 03-10-2006, 04:31 AM
LastBlack02SS's Avatar
Default STS hanging low
So my STS kit hangs low. I had a muffler shop weld up some braces but it is still low as all hell. I can post pics to give a better idea soon. I was actually wondering if there was anyone in the Sacramento, Davis area of northern california had experience with the kits and might be able to provide some in person advise.
Old 03-10-2006, 04:43 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...Car.php?car=32
We had the same problems with the camaro SS above. We made a bracket that is shown in some of the pics above that helped out. Bob
Old 03-10-2006, 10:28 AM
NYSS Guy's Avatar
There is a lot of room to be be gained by just adjusting the pipes, and the turbo itself. If you loosed up the center section of the turbo, it will allow the center section to spin, then loosen the pipe that attachs to the stock exhaust pipe. Rotate the entire assembly so raise everything up, tighten the center section with the oil fitting at 12 and 6 o'clock, and tighten the stock pipe section. That should gain you a bunch of clearance, that was the biggest gain I've seen. Good luck.
Old 03-10-2006, 01:07 PM
hissin'98's Avatar
^^^That's what I did and I gained about 3-4 inches of ground clearance. My wastegate was pointed straight back. Now that I adjusted it, it points at a downward 45* angle. It's just the matter of adjusting the pipes and the turbo.
Old 03-10-2006, 01:41 PM
trtturbo's Avatar
What everyone else said. You need to rotate the housings and the pipe that goes on the exhaust to get it up high. This car does not use any brackets or anything other that the 2 exhaust hangers.
Old 03-10-2006, 01:52 PM
Schantin's Avatar
I used TRT's pic here to get mine adjusted. I don't have mine clocked exactly the same way, but the muffler shop made a stepped over axle pipe for me (2 1/2"....and yes I know this is narrower than stock) to gain tons of cleaance. So, got a venturi effect going into the turbo and gained a truckload of clearance too. The over-axle pipe was what was limiting the turbo from "tucking into" the car.
Old 03-10-2006, 04:31 PM
99Z28LS1's Avatar
the trt car is mine and it sits extremely high. the bottom of the turbo sits at about the middle of the pumpkin
Old 03-10-2006, 04:42 PM
Koncrete's Avatar
look on the bright side, you can tell all the girls your "Hung Low"
Old 03-10-2006, 08:27 PM
shawn_c992001's Avatar
I just used some aluminum flashing about 1/2 inch wide and made a hanger. I wrapper this around the intake side of the turbo.
Quick Reply: STS hanging low
