what else will i need if i get this sts..
If i get the stage 2 from http://trtturbo.com/F-BodyStagepage.html what else will i need?
Ditch the A/F gauges unless its a wideband and get either a fuel pressure gauge or a wideband.Id recommend getting 60# injectors instead of 42's so u dont have to rebuy later on down the road if u upgrade.If your car is a stick id get pushrods and a clutch.If its an auto get a tad higher stall.Other than that it looks pretty complete.
their kits come complete with everything you need. but if you plan to go above 5psi then an intercooler or meth kit is need with new injectors and fuel pump. if you have a M6 then a blow off is needed and a clutch for above 5psi
